arcing between the the boot and block WHY!!
Old Dec 9, 2003 | 08:32 PM
z28ss9496's Avatar
Angry arcing between the the boot and block WHY!!
guys i have had this problem for a while now. my car is skipping because of it. It is arcing between the plug wire boot and the block. Not long ago i hade to replace a head gasket and ever since then i have had this problem. i have replace the plug wires and put new plugs in the car when i replaced the head gasket. i can put tape around some of the boots and some of the plugs will not arc. Yet some still do. do you guys think maybe i have recieved a bad set of wires or what. this is driving me crazy.
Thanks for all the help!
I am open for any ideas. ANY!!!!!!!!!!!!
Old Dec 9, 2003 | 09:05 PM
madwolf's Avatar
Usually arcing means a cracked plug (the crack may not even be visible) if you accidentally dropped it during install or hit it with a wrench, or a bad/burnt wire. What kind of wires did you use? Does it happen on all plugs?
Old Dec 1, 2004 | 08:05 PM
jerame20's Avatar
Re: arcing between the the boot and block WHY!!
i have the same exact problem did a wire, plug, and lt header install its arcing like crazy from the bottom of the boot to the head on cylinders 4,6 and 8 hadnt thought of the cracked plug thing might give that a whirl
GREEN3112
Feb 10, 2019 09:19 PM
Henson071
Sep 18, 2015 04:01 PM
heus
Sep 8, 2015 12:01 PM
Henson071
Aug 4, 2015 09:32 AM
detroitmuscle
Jul 31, 2015 04:21 AM
