Arcing
Old Jun 11, 2003 | 12:01 AM
Rodrigues's Avatar
Angry Arcing
I got brand new over the valve cover wires and put them in and now I have unsteady rpm's and large arcing across my coil. The rpms at idle arent very very consistant and my engine shakes. I have driven like this for around 500 miles and I dont seem to have any problems. I feel that there may be some power missing though. I have an MSD blaster coil, could this coil be going bad? I used die electric grease on everything, I can measure the resistance, but what is normal? Could the crimping be bad?
Old Jun 11, 2003 | 10:44 AM
hairbear21's Avatar
Ensure that the coil wire is good, plus going to heavy on the grease can cause problems. The dielectric grease is designed to create an "insulation" for electronic components. If you went o heavy on it, you can compromise the spark getting to the plugs.
Old Jun 11, 2003 | 10:19 PM
Rodrigues's Avatar
i tried a new coil wire, nothing. Its arcing millions of times between the outer coil metal part and the coil itself. Its almost like a constant glow of arcs.
Old Jun 12, 2003 | 12:08 AM
94GreenZ28's Avatar
If its glowing I think thats ok. If jumping then thats bad
Old Jun 12, 2003 | 12:18 AM
turbo_Z's Avatar
if the car shakes at high load/low rpm then you have a bad wire or wires... if you went with Taylors then thats would be your problem.
Old Jun 12, 2003 | 09:31 AM
Rodrigues's Avatar
Alright, I think I will try MSD's 8.5mm. I just hate having to drill those made for you looms though.
Old Jun 12, 2003 | 11:01 AM
hairbear21's Avatar
Are you saying that ALL Taylors are bad? If so, there are a TON of people here that have used them and NEVER had a problem
Old Jun 12, 2003 | 11:04 AM
Rodrigues's Avatar
Most people have had problems, do a search.
michaelzilinski
Jul 31, 2015 08:41 AM
Fastbird93
Aug 11, 2004 01:32 AM
96z
Oct 17, 2003 12:59 PM
speed76demon
Sep 7, 2003 09:51 PM
PatriotTA
Feb 27, 2003 11:19 AM
