Anything special to tell the machine shop tomorrow???
Old Nov 1, 2004 | 08:05 PM
texasTA's Avatar
I am taking my LT1 heads in tomorrow to the machine shop to have them machined to fit the Comp 987 dual valve springs for my CC306 cam install. Anything special I need to tell them? I told them I needed them machined for the valve springs, will they just know what to grind them to? Also, is there a optimal heighth that is needed when the valve springs are installed?
I guess, if you guys can think of anything I need to tell them, I would appreciate it.
Old Nov 1, 2004 | 08:57 PM
Z95m6's Avatar
Re: Anything special to tell the machine shop tomorrow???
don't take them to the machine shop, just grind the corner of the locator yourself and install them.
Old Nov 1, 2004 | 09:02 PM
turbo_Z's Avatar
You pulled your heads JUST to get the seats machined to accept the 987s!?!? Man that is a lot of work for something that isnt even necessary. All you have to do is grind on the locators at little. The springs are not the problem... its the oversized locators. But since you have the heads off you may as well get them ported and tell teh machine shop the locators are 1.5" in diameter.
Old Nov 1, 2004 | 09:07 PM
5.7LT1Formula's Avatar
magnaflux is cheap insurance. Also have them check the valve guides. If they hot tank the heads they will look like brand new..easy way to clean/degrease and its very cheap.
Old Nov 1, 2004 | 09:53 PM
ftransam1's Avatar
Z95m6 what exactly is the locater? I need to do this to my heads soon for bigger springs. Can you guide us through it really quick?
Old Nov 1, 2004 | 10:29 PM
Z95m6's Avatar
Here is a pic of the locator/seat. http://www.vthunder.com/base/images/...s/VT4770-4.gif
Just put the 987 seats on the head and you will see the little bump that sticks out and the seats catch on. Just notch that corner of the seat until the seat fits flush on the head. Then put the spring on. The seats are way larger than the 987 springs and thats why you won't have any problems.
Old Nov 1, 2004 | 10:34 PM
Z95m6's Avatar
TexasTA i posted in your last thread that you didn't need to pull the heads to install these springs. http://web.camaross.com/forums/showthread.php?t=313939
Did you decide to get your heads ported?
Old Nov 1, 2004 | 11:06 PM
texasTA's Avatar
Yeah, I decided to port them. but aren't those retainers that you showed in teh pictures? Maybe that is just the retainers other name, locators.
Old Nov 2, 2004 | 12:30 AM
5.0THIS's Avatar
Installed spring height is critical. read the manufacturer's recommendation and stick to that. You may need shims on hand, and a spring height checker as well, with your retainers and locks.
Old Nov 2, 2004 | 07:32 AM
OldSStroker's Avatar
If you are having them ported, the porter can do the spring pockets. If you are just having a general machine shop do the pockets, make sure they have done others and have the correct tool which makes the job a snap. If they don't you could be in for a big charge.
Dmonty
Jun 2, 2015 11:19 PM
Spcquinn
Apr 18, 2015 09:40 AM
drptop70ss
Mar 26, 2015 01:50 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
chuyz28
Nov 25, 2014 11:14 PM
