Anything im missing?
Old May 1, 2004 | 01:25 PM
LT1Squirrel's Avatar
Question Anything im missing?
for my tune up, which should happen tomorow will consist of:
plugs, wires, o2's, coil, and fuel filter....
is there anything that i am overlooking?
p.s.: oil was recently changed, trans/rear fluids will be changed soon
Old May 1, 2004 | 01:39 PM
emtcee1973's Avatar
pcv valve,air filter.when was the last time u flushed your rad?check hoses.
Old May 1, 2004 | 03:51 PM
OBE1 95Z28's Avatar
I don't think you need to change your coil, they either work or fail. If you have high mileage I'd take a look at the suspension parts (ball joints, bushings, rag joint) to see if they're looking ragged.
Old May 1, 2004 | 10:30 PM
rad was flushed like a month ago trying to chase a cooling problem...my bro gave me the coil
93 RedBird
Nov 15, 2015 08:24 AM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
Ks0209
Oct 1, 2015 07:32 AM
tommalcolm
Sep 11, 2015 03:39 PM
