To Anyone who thinks it may be the Optispark!!!
I always see "Is it my Opti-Spark?" questions. I want to point out one thing. When all else has failed, check this.....there is a small (about 1-2") vaccum hose that goes into the o-spark. Check this hose thouroghly for cracks or slices. I ran through the "is it my opti-spark?" thing when I had my 95. It tore me down, pissed me off, and just sucked. When I finally ended up deciding to change the Opti myself, I had it all apart and found the Opti was fine, it was that little $2 hose that had cost me weeks/months of frustration and nearly $300 in attempts to correct the infamous "stumble". You will need to get under the car or get it up on a lift to really check this.
I just wanted to share my knowledge and maybe make soemone else's life easier.
BamaZ28
BamaZ28
NegativeCreep,
Let me guess....nirvana? I am a big fan of the late Kurt Cobain.
Anyhow, to all others, this may seem like a small insignificant peice, but it can lead to the "opti-problem"
BamaZ28
PS It may not have been a "vacuum hose", I'm not sure of the real function, but it was what fixed mine. It resembles a vacuum hose.
BamaZ28
kandied91z
Mar 3, 2015 11:34 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
