Anyone using Racetronix injectors?
Old Feb 12, 2006 | 02:18 PM
12SCNDZ's Avatar
I'm going to follow a few pieces of advice and ditch my Accel injectors. I'm looking at a set of 37# Racetronix. Anyone using them?
Thanks,
Frank
Old Feb 12, 2006 | 02:21 PM
Jameslt1TA's Avatar
Re: Anyone using Racetronix injectors?
Ive heard they work pretty good. I have a set of ford 36#s and they work pretty good also.
ps you'll have a pm about a 4l60e rebuild in about 2 mins.
Old Feb 12, 2006 | 02:33 PM
3gc's Avatar
3gc
I haven't heard much about racetronix but you might want to consider the 36# injectors from SLP. They're new GM / Bosch injectors for slightly less then the racetronix. I'm gonna be ordering them in about a month probably.
Old Feb 12, 2006 | 02:47 PM
89385formula's Avatar
I have the 37lb Racetronix ones. My new setup hasn't been fired yet, so i can't give feedback except they seem to be very high quality pieces.
Old Feb 12, 2006 | 03:03 PM
LameRandomName's Avatar
I'm using the 42lb racetronix injectors. No problems so far.
Old Feb 12, 2006 | 03:10 PM
Honda Hunter's Avatar
Are you serious? Anyways I have RT's 37lbs. Ill know real soon how well they work.
Old Feb 12, 2006 | 03:14 PM
30696bird's Avatar
Hey Frank, I have 37# Racetronix fuel injectors and they have worked great so far. I have had them for over a year.
Old Feb 12, 2006 | 04:05 PM
magnumv8's Avatar
I have been using Racetronix 42# for a little over a year with no problems
Old Feb 13, 2006 | 09:54 AM
bn_bullet's Avatar
I have the 37 pound Delphi/Lucas injectors and have been very pleased with them. I have been using them for 18 months now with no problems. On my application, I discarded the fuel injector retaining clips because there was no provision for them on the injector body but this has had no detrimental effects.
Brian
Old Feb 13, 2006 | 04:04 PM
Originally Posted by Honda Hunter
Are you serious?
Who? Me?
If so, then yes.
I'm anxious to get to the track this spring. With the new 255 walbro and the bigger injectors is FEELS a lot stronger. Like a tenth or two.
Which probably has more to do with my old injectors being tired, but there IS something to be said for a small duty cycle.
Old Feb 15, 2006 | 12:52 AM
Racetronix's Avatar
Huh?
SLP Bosch / Delphi 36 = $40.62 each x 8 = $324.95
Racetronix / Delphi 37 = $34.99 each x 8 = $279.92
Old Feb 15, 2006 | 12:12 PM
ksmyss's Avatar
im running the raetronix 37s. work great, zero problems
Old Feb 15, 2006 | 01:02 PM
3gc's Avatar
3gc
Originally Posted by Racetronix
Huh?
I was basing my prices on the Thunder Racing website and SLPonline.com. Racetronix injectors are $332.99 on thunderracing.com and the SLP injectors are $324.95. I didn't realise you offered the injectors direct from your site. Glad i didn't order the SLP ones just yet, thanks.
Old Feb 15, 2006 | 02:27 PM
Ricardo's Avatar
I did exactly what you are doing, Frank. I ditched a set of Accel 30# in favour of the racetronix Delphi/Lucas 37#. First thing I noticed was faster starting after stopping the engine for a while (30 min- 2hrs). Apparently the injectors were leaking and flooding the engine. It also idles much smoother.
RG
Old Feb 15, 2006 | 05:01 PM
12SCNDZ's Avatar
Huh?
Ok, would the 37# injectors be the best decision for my application? 12:1 compression, 6" rod, 355 with race ported LT1 heads with 2.0"-1.56" valves, 234*/242* .575"/.595" hydraulic roller, ported LT1 intake with 58 MM throttle body. A4 transmission with 3800 stall, 3.73 gears, 3200# '93 Camaro with a 200 shot of progressive "wet" NX. Cam RPM range is 3000-6500.
Thanks,
Frank
