Anyone use this from SLP ????
Old Nov 30, 2004 | 12:19 PM
AZ2ENVY's Avatar
I just seen these . They are bolt on sub-frame connectors . Whats
better the bolt ons or the weld on sub-frame connectors ? Is anybody
using the bolt-on type ? Thanks .
http://www.slponline.com/view_produc...01&BIG=70801-1
Old Nov 30, 2004 | 12:33 PM
Z06Z28's Avatar
Re: Anyone use this from SLP ????
Do a search in here for SLP and Global West subframes. Theres also BMR, Hotchkis and many others that might catch your eye. I would recommend Weld-In subframes because some guys I heard that have Bolt-Ins have experienced the bolts backing out and stripping due to the body flex after time. Weigh out your options of what brand since some subframes may hang a lil lower than others and cause clearance issues if your car is lowered. I just bought a Hotchkis two point Weld-In so thats what I went with.
Old Nov 30, 2004 | 12:37 PM
CamaroBoy96Z28's Avatar
You could go with bolt-ins and have them welded but that would add unecessary cost. Hotckis, SLP, Global West and what I use, BMR are all good and get the job done. Definitely get them welded though. Also depending on your power goals and clearance desiribility, you could get either boxed or tubular SFCs as well with the tubular sacrificing a little strength but having the best ground clearance.
Old Nov 30, 2004 | 02:16 PM
93turbo5oh's Avatar
im very happy with the SFCs that www.wolferacecraft.com installed on my car
Old Nov 30, 2004 | 05:47 PM
Frank89IROC's Avatar
On my 94 Trans Am I installed the Jegsters from JEGS, They are bolt on, which made it easy for me to do, I then took the car to a muffler shop, where I also had them welded (for $20.00).
Old Nov 30, 2004 | 09:24 PM
Bersaglieri's Avatar
I like Hotchkis ones, since they are the only boxed SFC specificly engineered to give you maximum ground clearance. Weld in of course. SLP are also nice, BMR is ok, but I am bit concerned with their quality anymore. Of course the less metal the lighter the SFC, dont forget.
-Dustin-
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
sahlomonic
Parts Wanted
Sep 22, 2015 03:13 PM
tommalcolm
Sep 11, 2015 03:39 PM
rideordie
Sep 7, 2015 08:22 AM
