anyone trap 110mph on stock heads N/A?
Old Mar 10, 2004 | 03:43 PM
mkent's Avatar
was just wondering if anyone is running that fast on stock heads N/A. was researching some different cams and it seemed like most would be around 105-108mph on stock heads. if you've reached this mark, how are you doing it?
Old Mar 10, 2004 | 03:45 PM
96ta(nick)'s Avatar
i am only trapping 113 with my cc306/heads
Old Mar 10, 2004 | 03:47 PM
jchevy's Avatar
I am trapping 104 with stock heads and cam. I have a friend with cc306 cam, heads havent been polished or ported, but has bigger valves installed and he is trapping around 113 mph i beleive.
Old Mar 10, 2004 | 03:51 PM
JZ 97 SS 1500's Avatar
I trapped 110.51 with stock motor, bolt-ons only. Car weighed 3715lbs, and its a 6spd. I had the usual bolt-ons. Headers, cat-back, K&N FIPK, MAF ends,52mmTB, msd6al, skinnies, ET streets, LT1 edit..etc
Old Mar 10, 2004 | 03:57 PM
JuicedTA's Avatar
Trapped 109.99 and then 110.31
Auto
97 TA
CC305 cam
STOCK HEADS
3:73
Hooker Long Tubes
3500 Vig
Very dry and cool day (45 - 50 deg outside that day.)
Ran 12.23 @ 110 4 times that day.
Track Elevation 1300' (Noble Oklahoma)
mkent's Avatar
reason i ask is i'm looking into getting the 218/224 comp cam and longtubes and a tune. will do gears at some point when summer rolls around too but i was just wondering if 110 without headwork was possible.
Old Mar 10, 2004 | 03:59 PM
mkent's Avatar
Auto
97 TA
CC305 cam
STOCK HEADS
3:73
Hooker Long Tubes
3500 Vig
thanks 97TA, i think you just answered my question. maybe your car is just a freak though, is anyone else having this kinda luck?
Old Mar 10, 2004 | 04:01 PM
JuicedTA's Avatar
I don't remember what it weighed that day, but I did have slicks and skinneys on. I would guess around 3600 w/o me (200+)
I also had a custom X-pipe exhuast that took me from 12.60's at 106 to 12.20's at 110 that day.
Also had a 52 mm TB and en Ed wright tune.
Old Mar 10, 2004 | 04:02 PM
GREGG 97Z's Avatar
Stock untouched heads and the little hotcam, trapped 115. Trapped a best of 109 with boltons though fwiw.
Old Mar 10, 2004 | 04:10 PM
Z94SLEEPER's Avatar
I have trapped a little over 110.15 so far with stock heads and cam. Next I plan on adding 1.7 roller rockers to give me an added 1-2 mph along with some more tuning. I am expecting to run mid to high 112 trap speeds B4 I go into the motor and add a cam. I also have a goal to break into the 11's with no cam too but will need much more suspension work.
L8TR,
96ta(nick)'s Avatar
hmm something must be wrong with mine... maybe i am getting KR?
my heads flow 267/195 with 2.00/1.56 valves with a comp 306 full boltons 3600lb(me in it) and i am only trapping 113...
xxsaint69x's Avatar
trap 115 on stock heads with CC306 and not even all the bolt ons.
Old Mar 10, 2004 | 04:11 PM
MauriSSio's Avatar
it seems the 97's and some 96's run a lil stronger than the 93-95-96 1/2
Old Mar 10, 2004 | 04:13 PM
96ta(nick)'s Avatar
see now that makes me mad
Old Mar 10, 2004 | 04:15 PM
JuicedTA's Avatar
Nick,
It's seversal things,
tune
weight
60' time
weather
location of track
Don't forget everyones car is VERY different.
