Anyone read that 1.7 rocker thread?
Old Oct 20, 2003 | 04:59 AM
jasycZ28's Avatar
I was thinking of using the 1.7 rockers with a CC305 and when emissions rolls around throw back in the stockers or 1.6's which I all ready have. Would this set up be bigger than the CC306? What do you guys think of this. I plan on installing the CC305 in a forged 383 with aftermarket stage II heads. Would this pose any problems?
Old Oct 20, 2003 | 06:31 AM
grygst76's Avatar
define "bigger." you'll get more lift, otherwise the other numbers stay the same.
Old Oct 20, 2003 | 10:35 AM
jasycZ28's Avatar
Well I am not sure but wouldn't it make it seem like it is a bigger cam? If so would it make it too big for a street car?
Old Oct 20, 2003 | 10:43 AM
94 CAMRO Z28's Avatar
Not to steal the thread but does anyone know what the lift would be on the hotcam with the 1.7 RR. I already have 1.6s but it seems like a very easy mod for a good hp increase. Thanks
Aaron
Old Oct 20, 2003 | 10:45 AM
i387's Avatar
Re: Anyone read that 1.7 rocker thread?
You'll get more lift, but your duration and LSA won't change. The CC305 has a 114* LSA, the CC306 has a 112* LSA (stock in the '95 is 116* just for reference).
lower LSA = more peaky, top end power
higher LSA = broader power, better emissions
Old Oct 20, 2003 | 11:01 AM
PoorMan's Avatar
Hotcam lift would be .5578 or .558 w/ the 1.7's. I don't think hotcam spring will handle that amount of lift.
Jeff D.
Old Oct 20, 2003 | 11:05 AM
BUBBA's Avatar
Just put the 1.7s on the exhausts.
Old Oct 20, 2003 | 06:24 PM
jasycZ28's Avatar
Well I did get the CC305 on 112 LSA. Does anyone know what the lift of the CC05 would be with 1.7's? I have springs that are good up to .600. Thanks
Old Oct 20, 2003 | 06:58 PM
Got-LT1's Avatar
Re: Re: Anyone read that 1.7 rocker thread?
not exactly, your duration will be increased by 1-3 degrees, usually 1 or 2.
I doubt that the cam would be to big for a street car.
EDIT: I know 1.6s increase lift by ~ .030, so maybe 1.7s are +.060?
Old Oct 20, 2003 | 07:14 PM
Cmr0z28's Avatar
both sides are .510".....with 1.5 rockers.....with 1.6 the lift would be 544. with 1.7's, the lift would be 578
Old Oct 20, 2003 | 09:55 PM
Black94mula's Avatar
Doesn't that start to **** up the valvetrain geometry when you use very steep rockers?
Old Oct 20, 2003 | 11:00 PM
jasons93z's Avatar
Just curious. How much HP would i get with a stock H/C with new springs and the 1.7rr's?
Old Oct 20, 2003 | 11:31 PM
kgkern01's Avatar
About 14 RWHP with hotcam w/1.7RR
Linky: http://www.kyfbodies.org/vb/showthre...light=scorpion
Old Oct 20, 2003 | 11:58 PM
drewstealth's Avatar
I would say you would gain somewhere around 13-20rwhp from going from 1.5 to 1.7 on stock heads and cam. Because that guy got 14 more from going to 1.7 from 1.6rr's.
Old Oct 21, 2003 | 12:44 AM
WS6T3RROR's Avatar
for the enlightenment of all people in this thread who can't calculate lift for diff rocker ratios.
new lift = (old lift / old rocker ratio) * new rocker ratio
EX. (using hot cam figures)
new lift = (.525 / 1.6) * 1.7
new lift ~ .557"
or if you know the lobe lift on the cam just take that times the rocker ratio and you have valve lift. just a few little pieces of auto math, good things to know
