Anyone plumb an Accusump on an LT1?
I am considering an Accusump and want to know the best place to connect it to the engine. I have a remote oil filter using an engine adapter from Canton. Should I tee into the return line from the oil filter or can you plumb it directly into the hole that is plugged above the filter mounting pad on the engine block?
