Anyone with Lloyd Elliot Flow Charts?
Old May 28, 2003 | 04:46 PM
pennys58's Avatar
I was wondering if anyone had flow charts from Lloyd Elliot heads. I went to a performance shop today to buy some valves for the port job Lloyd is going to do and he was trying to sell me on some port job they have for $600 that flows high 230's-240's And when I said that Lloyd could do in the 260 to 270 range with the 2.00/1.56 he was calling bs and calling all of these porters he knows inquiring about the flow numbers. He said that the most would be in the low 270's that he or his "porters" have seen on a stock LT1 head and the only person that could do that is this guy named Greg from Houston. So, I need some charts to call HIS bs. Thanks.
JOHN
Old May 28, 2003 | 05:07 PM
Timberwolf's Avatar
Here is a before and after chart for you:
http://www.kak.com/camaro/mycar.htm
Old May 28, 2003 | 05:24 PM
pennys58's Avatar
Thanks timberwolf, was that with stock or aftermarket valves?
JOHN
Old May 28, 2003 | 05:30 PM
llafro's Avatar
The only way to go is to have before and after numbers. Ask them to give you the flow numbers for a completely stock head, and then for the ported head. That is the only way you can see what kind of difference they make. The type of flow bench they are using and the way they set up the test also matter. For example you can't directly compare heads if one was flowed at 10" of water vs another flowed at 28" of water. 28" is more of a standard, but the 10" number is used for diagnosing problem areas.
My heads from Lloyd flowed 210 stock and 278 after porting. This was with larger than stock valves on a set of '643 castings.
BRAD
Old May 28, 2003 | 05:33 PM
llafro's Avatar
I found the numbers:
Before:
lift Int./Ex
.100 59/42
.200 110/79
.300 169/115
.400 206/135
.450 213/141
.500 210/144
.550 210/144
After
.100 64/55
.200 133/107
.300 192/133
.400 239/158
.450 251/171
.500 265/181
.550 272/184
.600 277/190
Old May 28, 2003 | 05:43 PM
pennys58's Avatar
Llafro, thanks for the numbers. Yeah, I'm looking for both numbers. This guy just really irrated the living hell out of me. He was like, "he's not telling you the truth" and said that he "is making leaks for better cfms" and that "he can say what he wants over the internet". I don't know lloyd personally, but have been emailing him for the past couple of months with him replying very thoroughly and I have come to trust what he says and I've seen numbers to go along with what he states. I just went in there for some valves and it turned into this big ordeal with him calling several people to prove me wrong. Then he says that he callibrates the bench to flow higher numbers and kept going on and on. I told him that when I got mine back that I would let him flow them. And he just kept going on and on...I was just getting royaly pissed off Thanks for all the numbers and keep them comming!!!
JOHN
Old May 28, 2003 | 06:00 PM
llafro's Avatar
It sounds like this guy just wants to sell you his services. There are a lot of people here using his (Lloyd's) heads, and they all seem pleased with them. His customer service is great.
Old May 28, 2003 | 06:30 PM
pennys58's Avatar
Yeah, I could tell that he wanted me to use his service, but I never asked for it and just wanted some dang valves...not a lecture on how wrong lloyd's numbers were.
Old May 28, 2003 | 06:32 PM
Loadre's Avatar
How much does Lloyd charge for his porting?
Old May 28, 2003 | 06:49 PM
Chris 96 WS6's Avatar
Lloyd is finishing up my big valve heads this week, I will post flow #'s when I get them, which should be in the next day or two.
Old May 28, 2003 | 07:03 PM
Speak of the Devil...I just checked my e-mail and Lloyd sent the flow numbers
Here they are:
.100 65/52
.200 135/103
.300 188/140
.400 238/164
.450 256/178
.500 269/184
.550 274/189
.600 276/192
Old May 28, 2003 | 07:08 PM
pennys58's Avatar
Sweet, thanks Chris...good numbers! Thanks for getting them on here!! Loadre, you can email him and he'll give you a great response with a quote for exactly what you're looking for.
John
Anyone else...post away
P.S. What kind of flow bench does Lloyd use?
Old May 28, 2003 | 10:20 PM
pennys58's Avatar
Late crowd have any input?
Old May 28, 2003 | 10:41 PM
97 RedSS's Avatar
Im pleased with my heads he did
Cody
Old May 28, 2003 | 10:43 PM
pennys58's Avatar
REDSS, do you have a chart or numbers?
