anyone know part # for mr gaskets .026 head gasket?
Old Oct 24, 2005 | 08:19 PM
red96z's Avatar
going to use this gasket more than likely when i put the heads back on to bump up the compression...... good idea??? anyways know part #.
Old Oct 24, 2005 | 08:31 PM
Deenasty's Avatar
Re: anyone know part # for mr gaskets .026 head gasket?
MRG-5716 from Summit Racing. Great Gaskets, im using them.
Old Oct 24, 2005 | 08:33 PM
jayrod's Avatar
How is everyone doing that when my Haynes manual says the most you can take off the head is .010?
Old Oct 24, 2005 | 09:16 PM
Deenasty's Avatar
Im running AFR heads, milled.015, and a .026 head gasket..
Old Oct 26, 2005 | 06:21 AM
Jeff95TA's Avatar
I'm using them too, but I had one problem with them. The coating on the gasket stuck to the packaging and pulled off when I opened it. I drove to Summit and had them open another package so I could get two goodones.
Could have been a one time problem though with the packaging process.
Old Oct 26, 2005 | 12:51 PM
1996LT1NY's Avatar
Originally Posted by Jeff95TA
I'm using them too, but I had one problem with them. The coating on the gasket stuck to the packaging and pulled off when I opened it. ICould have been a one time problem though with the packaging process.
Not a one time problem... a few months ago I used my first set of these & had the same issue. This month alone I've used two sets of em & went through the same thing again. I've had to use 6 pairs to get 3 pairs of good ones. Unfortunately Summit isnt in driving distance from here...
Old Oct 26, 2005 | 01:49 PM
Deenasty's Avatar
I called Mr. Gasket, and they said that if some of the coating comes off, it doesnt make a difference, I ran mine like that, and no problems..
Old Oct 26, 2005 | 02:07 PM
1996LT1NY's Avatar
All of the ones I had here had places where the coating came off 100% right down to the metal. Personally I would not take the chance use them like that even though they might be fine. Since Summit is willing to replace them for free allowing me to use the one good gasket from each package I will
Old Oct 26, 2005 | 02:16 PM
Deenasty's Avatar
oh, mine didnt go to the metal, just took some of the shiny black coating off, and left it like a satin black.
Old Oct 26, 2005 | 10:11 PM
red96z's Avatar
phil from AI called me today to tell me about the gasket coming apart and to watch out for that.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
