Anyone know the MPH shift points on an A4?
Old Nov 17, 2003 | 08:23 PM
ishz28's Avatar
Just wondering the stock MPH shift points, at WOT on an A4, thanks.
Old Nov 17, 2003 | 11:05 PM
Brent94Z's Avatar
Super Moderator
Stock tables for a 94Z...
http://www.bfranker.badz28.com/fbody/94zshiftmodes.htm
Old Nov 17, 2003 | 11:10 PM
Seal's Avatar
well that depends on the gearing... and some stock are 3.42, some are 3.23 and some are 3.08 and some are 2.73... how do i which one that used?
looks like 3.23s tho
Old Nov 17, 2003 | 11:13 PM
madwolf's Avatar
Only 2.73s and 3.23s were available stock on A4s from 93 to 02.
The tables posted by Brent are for a 3.23. Let me know if you need it for a 2.73.
Old Nov 18, 2003 | 02:32 AM
ishz28's Avatar
Thanks for the replies. I have 3.73's and am trying to get more power out of each gear. I also have an aftermarket cam, values, rockers, etc. I don't know how much those would effect the power bands for each gear? If so, I can list the mods that would help determine the best MPH to set the shifts at.
Old Nov 18, 2003 | 06:57 AM
zoso1959's Avatar
hi ion
tony here, any chance that you might know my shift points with
the 3.42 gears that i have.
great job tuning
thanks tony
Old Nov 18, 2003 | 07:09 AM
red94z28's Avatar
I got 273s and would like to know the shift points at wot if youd like to post them.
Old Nov 18, 2003 | 09:18 AM
S.J.S.'s Avatar
SORRY guys.....don't understand that table a bit.
Old Nov 18, 2003 | 09:45 AM
madwolf's Avatar
It's actually pretty simple. It shows the upshift and downshift MPH values for different throttle levels. Look at the top of the table and you'll see the percentages for throttle opening.
The WOT MPH for 2.73 gears are as follows:
1-2 - 48 MPH
2-3 - 92 MPH
3-4 - 150 MPH
2-1 - 29 MPH
3-2 - 86 MPH
4-5 - 142 MPH
Calculated lt1_edit values for 3.42 gears:
34
70
120
30
64
113
3.73s:
31
64
110
28
59
104
Old Nov 18, 2003 | 12:12 PM
ttopz28's Avatar
I was lost by the table too....All I knew was I have a punch at 29 MPH -- so I was trying to reference that. Damn me in my stupidity.
Old Nov 18, 2003 | 12:18 PM
madwolf's Avatar
That punch at 29 MPH is your downshift into first.
Let's take an example...
You start from a dead stop and drive about 5 MPH. Then you go wide open throttle. At 48 MPH / 5600-5700 RPM, it will shift into 2nd.
BUT... (looking at Brent's table)... say you only open the throttle about 1/4 (25%), then your car will shift into 2nd at 16 MPH....
Old Nov 19, 2003 | 09:22 AM
ishz28's Avatar
3.73s:
31
64
110
28
59
104
Thank you, this will help a lot. Right now, I'm stuck using a Hypercrap. Gear shifts adjustments are done in +/- Mph not Rpm's on mine.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Aneurysm
Jul 22, 2002 08:42 PM
