anyone that has done an OBD 1 conversion
Old May 24, 2005 | 06:32 PM
SickWS6's Avatar
i am working on doing this to my 96 and i need the pinouts that show where each wire goes i have akll the other stuff so if you guys could give me some advice that would be great.
Old May 24, 2005 | 07:09 PM
truedualws6's Avatar
Re: anyone that has done an OBD 1 conversion
I'm not sure what you are asking for. All you need is a knock sensor and
to have your ODBI PCM tuned appropriately. The rest is plug and play.
Old May 24, 2005 | 07:42 PM
jchevy's Avatar
Resistors can be soldered into the PCM so it can work with the OBD2 knock sensor. This is what I did, all i have to do to go back to obd2 is unplug the computer and plug the other one in. I dont remeber what pins i had to solder, do a search and it should come up.
Old May 24, 2005 | 08:28 PM
Brent94Z's Avatar
Super Moderator
If you are trying to get the pinouts for the connectors, it sounds like you are trying to do something you don't need to do. I have a 96 OBDI conversion and my car is like jchevy's... my OBDI PCM has been modified via a resistor to accept the OBDII knock sensor. If I want to switch between the OBDI and OBDII PCMs all I have to do is unplug one and plug in the other... nothing else.
Old May 26, 2005 | 03:10 PM
SickWS6's Avatar
Will the knock module out of an OBD2 Pcm work on an OBD1 PCM if i just swap them or does more need to be done
Old May 26, 2005 | 04:31 PM
jchevy's Avatar
Sensor itself reads a different resistance so resistors need to be soldered in to convert it to what the PCM is looking for. Do a search and info will come up on what you need to do.
Old May 26, 2005 | 06:47 PM
97Z-M6's Avatar
here you go just follow this i did it its no big thing.
http://web.camaross.com/forums/showt...rsion+resistor
Old May 26, 2005 | 10:19 PM
cpope's Avatar
Computer pinouts: http://shbox.com/1/4th_gen_tech2.html#1995_pcm_pinouts
shoebox is the man. I could not have done the lt1-s10 swap without him.
Old May 26, 2005 | 10:34 PM
SickWS6's Avatar
The PCM that i have has no Knock Module in it so if i swap the knock mudule from the OBD2 PCM to the OBD1 which i am putting in. will that be fine?
i have already soldered in the resistor. so i think thats all that i need is just the knock module
Old May 27, 2005 | 02:01 PM
Brent94Z's Avatar
Super Moderator
An OBDII knock module will work in an OBDI PCM. However, and OBDII knock SENSOR will not work in an OBDI car.
I have used an OBDII knock module (LT4) in my OBDI PCM with no problems as have several others.
Novo
Jun 14, 2016 02:58 AM
RUENUF
Mar 13, 2016 03:37 PM
tdigger9899
Sep 7, 2015 10:56 AM
4586
Sep 6, 2015 03:10 PM
Aug 7, 2015 01:26 PM
