anyone ever break this?
Old Aug 8, 2004 | 10:08 AM
flusz28's Avatar
trying to take my oil sending unit off behind the block, and the plastic top of it broke off..... there goes $25bucks anyone else ever have this happen?
Old Aug 8, 2004 | 10:34 AM
Dave89IROC's Avatar
Re: anyone ever break this?
everyone say no
it is not unheard of, they are pretty easy to break
Old Aug 8, 2004 | 10:36 AM
flusz28's Avatar
bought the sendign unit socket but tilted it alittle to get a rachet on it and ping the plastic broke- what a pain in the a$$
Old Aug 8, 2004 | 08:14 PM
Mystic97Z's Avatar
i broke one changing a clutch in a friends 97 z, taking the transmission out.
Old Aug 8, 2004 | 10:50 PM
flusz28's Avatar
how do i get it off since i broke the plastic top off?? how can i get it out of the block?
Old Aug 8, 2004 | 11:11 PM
944v8inDFW's Avatar
http://shbox.com/1/oil_pressure_sensor.jpg
if it is broken grab it with some vice grips at the thin large round section
if you are in / close to DFW i got one in my tool box i would give you
wont even ask why you were taking it off
Old Aug 8, 2004 | 11:15 PM
flusz28's Avatar
i have to remove it for the oil feed line for the vortech- s-trim i have. hmm my vice grips are to big well i live in Ohio so thats not close too you
thanks anyhow
Old Aug 8, 2004 | 11:18 PM
944v8inDFW's Avatar
right above the oil filter pad there is a plug that may be a much easier and better place for oil feed??
nothing to break off there just take a plug out providing of course your line will reach.
Old Aug 8, 2004 | 11:21 PM
flusz28's Avatar
well its more then just that- the feed line has a bunch of fitting and a pipe that thread into the block and the sensor gets located into the pipe fitting. so it has to be feed from that spot.. so you have a extra sending unit or vice grips?
Old Aug 8, 2004 | 11:26 PM
944v8inDFW's Avatar
i'll just agree it HAS to be in that spot not seeing the lines and whatnot. I would assume you got 1 feed line with a fitting that screws into a t fitting for the oil sending unit. Why not elimante the t and just screw it right into the block above the ooil filter pad ? might hace to by a 50 cent fitting at the hardware store. The spare one i got is a long style. Pay for shipping and its yours. just my 2 pennies
Old Aug 8, 2004 | 11:46 PM
The metal hex part is what the socket grabs, so it does not matter if the plastic part is even there.
Old Aug 8, 2004 | 11:48 PM
944v8inDFW's Avatar
BTW If you have the socket just use it. The socket just grips in the metal part of the sensor not the plastic piece.
Old Aug 8, 2004 | 11:49 PM
944v8inDFW's Avatar
DAMN shoebox you are just too fast!
Old Aug 9, 2004 | 11:02 AM
flusz28's Avatar
yeah but i can't get the rachet on the socket to turn it, not enough room.. my vice grips won't fit back there either...
Old Aug 9, 2004 | 11:19 AM
I think I used an extension and socket aiming from the brake booster toward the sensor. It only takes a little effort to break it loose, then it screws off easily.
