Anyone else breaking Comp polylocks?
I can't open the original pictures any longer but be sure that the allen-head set screw in the top is contacting the top of the stud near the top (within the hex area of the nut. If the studs are too short and don't extend up to the hex portion, all the stress of the set screw is being transmitted to the weakest part of the nut. Further, it may be counter-productive to tighten the set screws to an excessive degree. Breaking an ARP 7/16 stud is not an easy thing to do. 3/8 studs are less durable but even then, if they're breaking, there's something bad happening and the source of the problem needs to be identified. Not every thing that breaks on a high performance motor is the result of poorly made parts, Mexico and China notwithstanding.
Just wanted to bring this back up b/c I'm running into problems now as well.
I tightened my polylocks when I built the engine similar to 2QUIK6 per recommended by several on the board and they're so tight that I snapped a few sockets getting them out and some of the rockers are coming out complete with the stud. I went 1/4 lash with my setup... first 1/8 turn then tighten the polylock down with a socket, then set the other 1/8 turn holding the wrench and turning the polylock at the same time.
This is TOO TIGHT.
Going to end up replacing my polylocks and all my rocker studs now because of this. Careful with some of the info on this board!
My simple spring swap turned into a much bigger ordeal now.
This is TOO TIGHT.
then i re-adjusted them using same method 3000 later i had about five that had cracks in them. got a new set and quit using this method and no problem since. just use a long handled allen and it should be tight
7/16" ARP screw-in studs
Since Bill indicated he was tightening them to 45 ft/lbs, I tightened all of mine to 42ft/lbs and still had 2 crack.
Yes, the cracks are well below the hex part, but the hex part is not very deep to begin with, maybe 3/8" at most, which I would not think is enough of the threads for the allen nuts.
A very good frind of mine that is a very good turbo Buick and LT1 mechanic told me that 42# is way too much, should be no more than about 30ft/lbs or as tight as a normal person can turn a regular size allen wrench.
The methods used above that are over tightening them, can be done and set the preload correctly..someone mentioned the lifter preload would be too much...but the way I had done it was to acheive a lifter preload of about 3/8 of a turn was to tighten the nut and allen set screw so that there was about 1/4 of a turn preload, then use the torque wrench to tighten the nut an additional 1/8 turn and acheive the desired torque setting..thus a total of 3/8 of a turn preload....but of course this results in too much stress on the rocker nut and causes it to crack....
So the correct way would be to turn the rocker nut to the desired preload...then llock it in place with the allen nut applying no more than 30ft/lb to the allen nut while holding the rocker nut in place so it does not turn.
Oh, sorry I had cleaned out my photo space and can't find the pics of the broken nuts to repost them, but there wasn't much to see except the rocker nuts cracked in half right at the bottom of where the set screw was, maybe a 1/4 inch down from the top...my set screws heads are just barely higher than the rocker nut top.
Mark each rocker nut so you can easily see how much preload they have once the allen nut is tight...for cams with more than .525 lift HR I would say about a 1/4 to 1/2 turn is fine total preload after the set screw is tight.
I'm sure everyone has a method for this, but 30 to 45 ft lbs on a polylock,
no wonder they are cracking. I have been going with 20 ft lbs on the nut
once the lock is set and have not had one come loose.
But also not all polylocks are created equal...I have an old set from back in the 80's for 3/8 studs that are probably 3/8" thick below the hex head, waay thicker and heavier than these Comps.
