Anyone dropped their transmission without help or a trans. jack?
Old Jan 25, 2003 | 12:32 PM
d3z28's Avatar
Question Anyone dropped their transmission without help or a trans. jack?
I am in the process of replacing the clutch, and wondering how difficult it is to drop a T-56 without assistance from someone else or a transmission jack. I have an adapter for my floor jack, but there is not enough clearance to use it while the car is on jackstands. Is it possible to balance it on a floor jack without the adapter? Any suggestions would be appreciated.
Old Jan 25, 2003 | 12:50 PM
96 WS6's Avatar
It's doable... me and a friend of mine lowered our trannies with two jacks. It took a couple times to get it perfect but you just get one jack on the front and one on the back and lower them at the same time.
Old Jan 25, 2003 | 01:16 PM
Josh 94Z's Avatar
A trans jack is not necessary. I have had mine out 3 times and only used 1 floor jack. (Like you, I bought an adapter for my floor jack and found out it wouldn't fit under the car. I think the only thing one would work on is a truck!) I would recommend having another person help you. The last time I took mine out, I had my wife run the jack while I did the maneuvering.
Old Jan 25, 2003 | 01:42 PM
d3z28's Avatar
Thanks for the replies
I may try to tie the trans the floor jack with some rope just to be safe.
Old Jan 25, 2003 | 06:04 PM
JohnD's Avatar
I did an m-6 twice alone. I built a jig out of 2 2x4's and a piece of plywood that put each of the 2 x 4'sw on either side of the transmission at the bottom. I use a floor jack under that and put a small ratchet strap around the jig and the trans to hold it. I had the car up higher than I could with stands. I mortared two concrete blocks together and had two pcs of 2 x 4 on top of each one and it was just about right. that reminds me I need to do it again. Damn clutch-and I don't even race.
Old Jan 25, 2003 | 06:45 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: Anyone dropped their transmission without help or a trans. jack?
I did. Right on my foot. Broke a few toes.
Now can say I have blood (10'' cut down my spine- bled through 2 shirts), sweat (you want to gut an LT1 in june?) and tears ( something fell on my face, hit my nose and made me tear)
Old Jan 25, 2003 | 06:51 PM
IllusionalTA's Avatar
the M6's are easy by yourself as long as you don't have a mufflex ypipe and a spohn torque arm.. best bet is to use 2 peopel but i have done mine by myself w/o any negative results other then some offended neighbor's
Old Jan 25, 2003 | 07:33 PM
78z28's Avatar
Its not that hard, all you do us get your chest under it and slide it back of the torque converter or off the crossmember and let it lay down on your chest, but you have to have the car up high enough so that you can slide it off of you onto the floor. Now i know you think its heavy and all but it really isnt you just gotta do it. but a jack will work too
Old Jan 25, 2003 | 09:57 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
I agree. The wife comes in handy when doing this, plus she likes to help out with the car. Have done it many times by myself. This resulted in me saying every cus word in the book, but I got the job done.
Old Jan 25, 2003 | 11:26 PM
Brent94Z's Avatar
Super Moderator
I've used a floor jack to drop a M6 before. It's a balancing act but doable
Old Jan 26, 2003 | 12:39 AM
fastang's Avatar
I have never done an m6 but I have done several mustangs and that's all I do...As long as you don't DROP it on yourself, they really aren't that heavy....But a jack is handy when doing the reinstall....
Old Jan 26, 2003 | 07:53 AM
NtenseZ28's Avatar
Gheez...where do you find a woman like that? All the girls I've been with just bark cuz you're working on ur hot rod, instead of paying attention to them! At this stage, asking my g/f to help me with my car would be like asking a big doberman to cough up that huge T-Bone steak that you gave him. I've had the 4L60-E out of my brother's stroked formula twice with just the assistance of a floor jack. It is handy having someone with some mechanical backround running the jack. Saves a lot of swearing and possible other injuries to yourself and your 4L60-E
Victor Lamb
Aug 26, 2017 02:52 PM
jackpawt883
Feb 26, 2015 09:04 PM
Jan 5, 2015 07:14 PM
Rich_z28
May 6, 2003 08:38 PM
JasonD
Aug 16, 2002 11:52 AM
