Anyone doing?
I don't think it will get super cold, just cool, and it probably will not condense on the inside of the TB too much because the air is not pressurized?
but the egr is exhaust going back into the intake which is hot and co2 is very cold when it comes out of a bottle. what temp do you think nitrous is after it gets let through the little valve on the bottle (it get very cold) and pistons don't crack from that do they? just use co2 in moderation and it will work perfect probably better then the equal amount of nitrous
I think thats why they always say to use forged piston for boosted/nitrous. I'm sure not going to spray freezing or cold pressurized air onto a baking piston
lets try it this way since your a "carpenter" have you ever accidentally touched one of the copper tubes on a gas powered compressor or that short rubber line on a little pancake compressor there hot that means if you put 2 and 2 together air gets hot when compressed. when a gas gets let through a tiny hole at a great speed it gets very cold (the way an ac system works) well I just realized I could have saved all this typing ... how does a diesel engine work? compress the air so much it get so hot that when the fuel is injected it explodes without any spark. when you pressurized air it does not create moisture the moisture is already in the air when it get compressed there simply is not enough room for the water to be mixed into the air anymore so it forms as condensation and collects
Yes you would think the air/CO2 being cycled by the EGR is hot and it is but cold compared to combustion temps.
Yes, that's why you always drain the air out of an air compressor because it will fill with water and when you drain it ice builds up on the release valve just like the exit/drain holes on a charge cooler or the TB butterflies/IAC. I don't use a gas compressor I use electric with a diaphram pump so it doesn't get as hot but the "pump friction" gets hot.
A diesel has "glow plugs" man, please!
http://en.wikipedia.org/wiki/Glowplug read last paragraph of method of operation
Large engines
Large diesel engines, such as those used in heavy construction equipment and locomotives, do not need glow plugs. Their cylinders are large enough that the air in the middle of the cylinder is not in contact with the cold walls of the cylinder, and thus retains enough heat to allow ignition.
