Anyone change torque arm bushing?
Old Dec 11, 2003 | 07:00 PM
Ronin's Avatar
I noticed the bushing on my car looks pretty chewed up. The dealer says I have to buy the two brackets to get the new bushings. I really don't like polyurethane but may consider it. If you changed your torque arm bushing please post what you used and how you liked it. Thanks
Old Dec 11, 2003 | 07:27 PM
Red_94Formula's Avatar
you can use the stock clamp with an aftermarket bushing. I did, but i had to drill out the rivits that held the stock one in. Once i did that my new ES poly slid right in no problem. I noticed no differnce in noise or traction with it. Now i have a spohn tq arm.
Old Dec 11, 2003 | 07:56 PM
MentalCaseOne's Avatar
Is this a tactful way to say dont waste your money on it?
Marvin
Old Dec 11, 2003 | 09:35 PM
sleepy_z28's Avatar
I went with the ES poly mount due to lack of funds for the torque arm upgrade. I think it's a good piece for the few bucks it costs.
Old Dec 14, 2003 | 03:55 AM
How long did it take you to swap old for new one? Can it be done in a few hrs and did you need any bolts screws or miscellaneous parts/items to replace it with the ES?
Marvin
Old Dec 14, 2003 | 04:15 AM
revtime's Avatar
Make sure you have the right tools to do it.
I used a dremel and it took awhile but air tools and a cutoff wheel would make quick work of it.
Once you get the old bushings cut out of the clamshell its pretty simple, the only problem I ran into was trying to get the clamshell closed enough to get the bolt started, I finally clamped it with some vise grips and it went back together.
If its the first time doing it I would say 2 to 3 hours depending on how fast you can get through the rivets.
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 5, 2015 03:43 PM
Jason Short
Jan 19, 2015 06:34 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
