anyone with a bit of information...
Old Nov 2, 2004 | 01:29 PM
GoTopless95Z's Avatar
any help at all would be good help...I have an almost complete LT1 motor sitting in my garage with no car to put it in and i want to convert the block so that i won't need to run the fuel injection...any ideas what i need to do to get this done? how do i compensate for the water pump, the opti, and so on and so on?!
Old Nov 3, 2004 | 04:30 AM
slopokrodrigez's Avatar
Re: anyone with a bit of information...
You can use this intake from GMPP number 24502592 LT1 Intake Aluminum Manifold. It uses a carburetor. I don't see why you think you have to remove the water pump or the distributor though. Unfortunately you have to stay with the reverse flow water pump but you can change it to an electric unit. You could switch to a rear mounted distributor but that's a bigger hassle than it's worth.
Double aught
Oct 2, 2015 11:29 PM
greenzee28
Sep 25, 2015 04:29 PM
Greg88
Sep 20, 2015 07:14 PM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
