anyone with a 58mm TB want to do me a favor?
Old Dec 29, 2003 | 10:17 PM
jonaddis84's Avatar
Any TB will work, preferably BBK though. If you have a gasket for one laying around, possibly scan it for me at 100% so I can use it as a template to work on the TB holes in the intake.
Running out of things to do before I get parts
Old Dec 29, 2003 | 11:19 PM
Brent94Z's Avatar
Super Moderator
Any throttle body will NOT work The BBK has its holes drilled on center as compared to the stocker but, for example, the AS&M does not! So, you'll want to be sure to use a BBK gasket for your template
Old Dec 30, 2003 | 09:54 AM
jonaddis84's Avatar
Ahhh, thanks Brent....didnt realize that....nowwww, anybody with a BBK 58 mm want to help me out??
Or does someone know where I can just buy a gasket?
Old Dec 30, 2003 | 11:14 AM
AxeGrinder30thZ's Avatar
I had to purchase my BBK 52mm TB gasket kit from Summit. Cost me $12.
Old Dec 30, 2003 | 02:49 PM
llafro's Avatar
I did the porting to put my 58 on the intake. The porting was concentric. You could just add 3 mm all the way around. If you are using a die grinder or a dremel, it's not an exact thing anyway. Once you do the porting, put the TB on and open the blades to feel for any edges. Remove them and you're good. I only used the template to mark.
Old Dec 30, 2003 | 08:49 PM
jonaddis84's Avatar
There inlies my problem though, I do not have the TB yet, I am just looking for things to do since I do not have parts to do anything with yet, just thought someone might have a gasket they could scan so i could use it as a template, i have already removed approximitely enough, but want to make sure its enough
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
truecontr3
Oct 11, 2015 09:30 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
bunker
Aug 1, 2015 09:47 PM
