Anybody running low 11's or 10's on motor with a lt1
Wanted to compair my specs on my set up to anybody out there with a 93-97 lt1 powered f-body that is running 10's or low 11's heads and cam combo trans and diff type with rear ratio with 60 foot time and mph please.
Im not up and running yet but my combo is 383lt1 solid roller cam 609 lift intake 578 ex 244@50 int 248 @50 exh tpis mini ram intake manifold afr 210's fully ported 1300cfm throttle body kooks 1 7/8"stepped headers acell dfi ecm and harness, th 400 trans with a gear vendor 3800 stall converter strange 12 bolt 4:11 gears bmr complete front and rear suspension qa1 12 way adjust shocks alll around . Just wanted to compair my specs to anyone who is already running these times
thanks
thanks
Sweet. After 2 more brake lines trans and oil lines we get to tackel all the fun wiring then hope fully im up and running. I only get 1 day a week to mess with it sometimes. So hopefully sometime early next year im up and running. I was hoping for a high 10 best low 11 worst case
A huge-cammed solid roller 383 stroker with AFR 210s, tunnel ram, Accel DFI with a monoblade, 1 7/8" headers and a TH400 better run a hell of a lot faster than low 11s, pending you have it tuned right, both in the suspension and motor.
Yes you should be low 10s maybe faster with a stalled TH400. It's all about traction for you, you should have all the hp needed to be in the low 10s maybe 9s. If it is tuned good and you get traction I think you will be surprised on your first run.
Suspension is all adjustable its just going to be get out there and make adjustments until it works. Tuning is the other everybody ive called only tunes factory ecm's for the ls cars i dont know anybody that can tune the acell dfi comp i have much less any one that is good at doing it
Depends on how heavy the car is and the trans/rear end set up. Some guys have seen 11s with boltons only; but these cars were high stalled cars with upgraded rear gears. If your looking to run fast with minimal hp, for a m6 you will need a good driver, and for a auto a good stall is a must. I like how people on the street see my car and say, "oh its a auto so it's slow"; no stalled autos are faster than m6 cars.
What stall is your converter and what axle gears?
