Anybody runnin GM guideplates?
Old Apr 11, 2009 | 01:17 AM
udlose94z28's Avatar
bought these specifically for the lt1 alum. head but heard they may be unhardened? To check before install? How do you go about this?
Id rather buy something right now rather than to go back into it while its in the car and the intake is on and reset the rockers
Any advice is appreciated
Old Apr 11, 2009 | 02:43 AM
bombebomb's Avatar
I am, I was also warned. I only have 200 miles on my engine so my input means next to nothing. But I heard the same thing so keep an eye on them.
Old Apr 11, 2009 | 05:53 AM
97pontta's Avatar
A simple way of checking if they are hard is to use a file on them. Try to file on a spot where it won't effect the guide plate. If the file "sings" which means it just rubs or may scratch the plate a little, the plate is hard. If the file cuts into the guide plate it isn't hard. This will not tell you how hard the plate is just give you an idea if its been hardened.
Old Apr 11, 2009 | 08:43 AM
Check them with a file as already mentioned. In the past, people reported that some of the plates were mistakenly unhardened.
An alternate would be the Trickflow Part # 30400623-8.
Old Apr 11, 2009 | 02:21 PM
jer4251's Avatar
Ive got the gm guideplates. about 4k miles on them sofar with no issues. gm 847, hardened pushrods and 918 springs, pro mag 1.6 rr's
Old Apr 11, 2009 | 03:36 PM
RamAir95TA's Avatar
I used the GM plates for about 1000 miles, then switched to the Trickflow hardened plates. Didn't have any abnormal wear on the GM plates when I switched them out.
Old Apr 11, 2009 | 08:28 PM
madhatter's Avatar
The GM plates were used for years before the Trick Flow ones came out. I wouldn't worry about them.
Old Apr 11, 2009 | 09:45 PM
truedualws6's Avatar
Just check the GMPP guideplates first. I've had one sent that was not hardened
and a second set that was. I'm using the Trickflow guideplates now.
Old Apr 11, 2009 | 10:21 PM
Bersaglieri's Avatar
I had problems with my GM ones, I went with ISKY adjustables with my cam swap and they are working great.
-Dustin-
KamikaZ28
May 28, 2015 12:45 AM
Catmaigne
Dec 25, 2014 12:16 PM
ltlhomer
Apr 4, 2003 01:55 AM
Joe Brodman
Mar 8, 2003 08:06 AM
SVT Killer LV
Feb 17, 2003 05:02 AM
