Any recent problems with LT4 ED timing set
Old Jan 10, 2006 | 03:39 PM
Walkersteelhead's Avatar
I am getting ready to order a timing set but I want to stay with the stock water pump. Has anyone had any problems with the LT4 ED timing set. I don't want to pay the money for the comp cams one. Thanks ahead for any input.
Old Jan 10, 2006 | 04:17 PM
z96's Avatar
z96
Re: Any recent problems with LT4 ED timing set
i have it my 383 no problems here. my engine builder only us them on his
rebuilds
Old Jan 10, 2006 | 05:24 PM
Don 97 SS's Avatar
The GMPP's LT1/LT4 Heavy Duty timing set is excellent. No problems from mine and it is so much better than the oem LT4 set.
Old Jan 10, 2006 | 06:15 PM
96flame's Avatar
No probs here just make sure you use the waterpump drive gear. Some guys don't change it and thats where the problems begin.
Old Jan 10, 2006 | 07:07 PM
truedualws6's Avatar
You can also search for more info. To quote 1racerdude:
If it is a build then check to see if the lifter oil galley plugs (at the edge of the WP gear) have a .030 hole in each one. If they don't there is your problem.
In all other installs where the WP gear is replaced it seems to be working
great, me included.
Old Jan 28, 2006 | 11:59 AM
Compstall's Avatar
Is there any alternative timing set to OEM out on the market that is better without converting to a late-model opti setup?
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Jazsun
Dec 29, 2014 12:14 PM
Z28STYLE23
Aug 17, 2002 07:40 PM
