any point in buying intake to practice porting?
Old Jan 24, 2005 | 09:10 PM
unvc92camarors's Avatar
planning on practicing porting heads then doing my real ones in the winter
just wondering if it was worth my time to practice on an intake
do you have to do much to the intake?
does it really need to be practiced on or is it just basically a gasket match?
thanks
Old Jan 24, 2005 | 09:46 PM
TransAmGT's Avatar
Re: any point in buying intake to practice porting?
Go buy an old set of heads or just a head from the junk yard and pratice on that!
Old Jan 24, 2005 | 09:56 PM
yea, that's what i'm going to do
i was just seeing if it was worth practicing on an intake- for the real intake porting
not sure if i really need to practice on a junk intake, so i can be ready for a real intake
sorry if i'm not explaining it clearly
Old Jan 25, 2005 | 11:13 AM
ttt, sorta need an answer (sorry the above one helped somewhat but isn't quite what i'm looking for) cuz i'm going to talk to this guy about buying one soon
would i really need to practice intake porting?
or is it so much like the heads that i can just practice on heads and call that it?
thanks
Old Jan 25, 2005 | 11:21 AM
FryedClutch's Avatar
from what ive seen with the lt1 intakes if your doing a crazy amount of porting and tapering it so its larger at the top of the runners you can run into some issues with taking to much off and breaking through the intake but if your just port matching then i wouldnt thing that a practice intake would be necessary
Old Jan 25, 2005 | 11:32 AM
thanks for the reply
i actually decided that i'll just practice on the heads, see what i do, and if it comes time later that i decide i need a practice intake, i'll just pick one up then
thanks for the replies guys
Old Jan 25, 2005 | 11:49 AM
curly's Avatar
I have an intake which I have gasket matched and poted for a TB, it has gone smooth and I never practiced on anything. I left the head porting to a machinist since I also went with larger valves and spings which required machining. Go for it.... just keep an eye on material thinkness while you're working on it.
Old Jan 25, 2005 | 11:51 AM
Bersaglieri's Avatar
Even if you did port the intake how much gain would you see over just porting the heads, 10-15 hp? I mean it had better be worth the time and money spent on practicing to get a decent gain.
-Dusitn-
Old Jan 25, 2005 | 12:01 PM
curly's Avatar
The LT1 intake flows VERY well from the factory. I only gasket matched mine because it is off the car and figured it couldn't hurt anything. I had to port for the TB anyway.
oldschool
Feb 9, 2016 09:21 PM
pimpss96
Feb 12, 2015 01:28 PM
LT14LIFE
Feb 9, 2015 09:35 PM
MadMav
Feb 6, 2015 11:02 PM
