Any Pics of Destroyed Optis?
Old Oct 10, 2005 | 09:38 PM
Steves396lt1
Guest
Posts: n/a
Just need some photos of bad Optis. Looking also to see if any really had catastrophic failures with cap, rotor etc etc
Old Oct 10, 2005 | 09:43 PM
matt65's Avatar
Re: Any Pics of Destroyed Optis?
Just had mine replaced, nothing worth seeing though.
Old Oct 10, 2005 | 09:50 PM
Steves396lt1
Guest
Posts: n/a
I would like to see one that really caused damage, like a High RPM destruction.
Old Oct 10, 2005 | 10:02 PM
1racerdude's Avatar
Man,that kind of stuff is to gruesome for public viewing.
Old Oct 11, 2005 | 03:11 PM
Steves396lt1
Guest
Posts: n/a
one more time
Old Oct 11, 2005 | 03:25 PM
96TurboTA's Avatar
I've got one with a destroyed rotor and cap. I'll try to get some pics up later. It appears the rotor came into contact with the cap and all hell broke loose.
Old Oct 11, 2005 | 03:28 PM
Jameslt1TA's Avatar
I think 90% of the time the opti is destroyed due to the dowel pin on the camshaft being too long. The dowel pushes on the opti and causes it to turn out of balance and break things.
Old Oct 11, 2005 | 03:45 PM
Steves396lt1
Guest
Posts: n/a
I just want to see an Opti that is destroyed. My dowel was set by More Performance when I ordered my cam, and I measured it to be within Specs for a 96 LT1, which the motor is.
Old Oct 11, 2005 | 08:48 PM
Bad64chevelle's Avatar
I need to upload my pics of my opti. I also have a 15 second video clip after I lit it on fire... yes I hate the opti that much!
Old Oct 11, 2005 | 09:19 PM
turbo_Z's Avatar
http://www-personal.ksu.edu/~bperkins/opti.jpg
The only opti that has ever failed on me failed at 4k rpm!
Old Oct 11, 2005 | 10:24 PM
Bersaglieri's Avatar
Mine isnt going to show much, it was just corroded on each terminal and on the rotor. I dont know how, but you think they would use non-corrosive meteals.
-Dustin-
Old Oct 11, 2005 | 10:30 PM
Steves396lt1
Guest
Posts: n/a
Fire Fire yes, fire!!!!
Old Nov 12, 2005 | 08:52 PM
Steves396lt1
Guest
Posts: n/a
Here is mine. What a brittle piece of plastic this rotor was.
Old Nov 13, 2005 | 11:36 AM
Z28WannaB's Avatar
LOL That is hillarious. I've got to say they could have done a lot to make the opti a much better product. Like water proofing it, and not making it 99% out of plastic, and not using corrosive metal inside.
If they did the above mentioned things, it would probably never need replacing.
- Z28WannaB
Old Nov 13, 2005 | 09:05 PM
Maldo's Avatar
this is not uncomon for optis to fail like this (i see it all the time)
