Any good weight saving tips for a 95 Z28 convertible?
Old Oct 19, 2003 | 06:25 PM
Cerwin Vega Fan's Avatar
Question Any good weight saving tips for a 95 Z28 convertible?
Well, as you guys know verts are kind of heavy, (if I would have known this I may not have gotten one) my weight from the factory is 3480 (kind of weird that it is lighter then a LS1 vert ). Add the stereo and your talking over 3500 easily so yeah it needs to go on a diet. My question is what could I take off this car to bring back down to its stock weight or if I could even get it to go under its stock weight that would be great. I already have the most basic one covered, plan on taking out the spare tire out soon. So guys any ideas would be greatly appreciated on helping me get my car to lose a few pounds.
Thanks for the help,
Chris
Old Oct 19, 2003 | 06:47 PM
crAzy95z28's Avatar
yep spare tire, back seats, egr system and air pump, cat converter, ummmmm what else.....you could take off your stock springs i think and run on just the shock or im thinking it the other way..i dunno i read a topic about that..some guy ran his car without springs i think...i know there are alot of other things you can take out but those are the most common ones you can take off!! well im sure youll get more post.. good luck to ya!!
Old Oct 19, 2003 | 06:56 PM
Zack's Avatar
take out the stereo
Old Oct 19, 2003 | 07:03 PM
pelebkf's Avatar
Take of the springs??? Can you really do that without detroying your shocks???
Old Oct 19, 2003 | 08:00 PM
REV IT UP's Avatar
Depending on how bad you want to get rid of the weight, you can remove the bracket on the passenger side of the engine that houses the alternator, power steering, and a/c compressor. You an buy an alternator relocation bracket that will enable you to install it at the bottom of the engine where to the a/c compressor originally was located. It's hard to drive one all the time like that without power steering, but sometimes you have to make sacrifices in the name of horsepower.
Old Oct 19, 2003 | 08:11 PM
PoorMan's Avatar
What makes them heavier anyway? I bet the rear window alone on a coupe weighs more than my top and rear deck lid.
Jeff D.
Old Oct 19, 2003 | 08:17 PM
Larnach's Avatar
Yes... go ahead and remove your springs, take your shocks out while your at it, no point in having those in there, just added weight. The bump stops could go while your at it.
That rack and pinion steering gear is pretty heavy, get rid of that... mind as well take out the engine too, but leave the transmission, you still need to shift.
Put a hamster and a cage in there, get some gears and get going.
oldschool
Feb 9, 2016 09:21 PM
92ragtop
Dec 27, 2014 01:56 PM
joe777107
Dec 1, 2014 09:32 AM
thenewkid
Nov 27, 2014 09:41 AM
squarehead
Nov 21, 2014 08:02 PM
