any gains from having a throttle body airfoil?
Old Jun 25, 2003 | 01:59 PM
ONELOUDKAR's Avatar
Does this thing really add 11.8 more HP and 36 more CFM? What exactly does this airfoil do? 11.8 HP from just adding this is marvelous, i thought to get 10 HP you had to spend around 1k.
-Mike
Old Jun 25, 2003 | 02:00 PM
FacelessZ's Avatar
No gains at the dyno with an airfoil...
Old Jun 25, 2003 | 02:06 PM
Bastardcat's Avatar
I think 11.8 HP is a slight overstatement.
Old Jun 25, 2003 | 02:08 PM
FacelessZ's Avatar
Makes you wonder where they got that sort of gain....MAYBE 1hp with a 58mm TB and tons of big mods...but 11?!
Old Jun 25, 2003 | 02:12 PM
ONELOUDKAR's Avatar
thats what i was thinking... i was fixing to whoop out the cc and purchase one. if 11 hp is the case, they need to find some more $50.00 items to give us 11hp
Old Jun 25, 2003 | 02:17 PM
bigsteve7's Avatar
I have never seen a gain from a airfoil... ever.
If it was such a bright idea youd wonder why the engineers didnt build it into the throttle body when they designed.
I'd put that $50 towards something thats actually proven to gain power.
Old Jun 25, 2003 | 02:18 PM
FacelessZ's Avatar
$50 electric superchargers on eBay...HAHA...probably money better spent...
Old Jun 25, 2003 | 03:02 PM
Antz97ZNJ's Avatar
Re: any gains from having a throttle body airfoil?
-Mike
lol, your reading some good advertisments, you might see 1 or 2 hp
Old Jun 25, 2003 | 03:42 PM
ONELOUDKAR's Avatar
yes, this item must be an overkill
Old Jun 25, 2003 | 07:21 PM
foxbat's Avatar
they do give a small gain of 2 or 2.5 hp. nothing you'll be able to feel, but every little bit helps! 2 here, 3 there, 5 somewhere else and you have 10.
Old Jun 25, 2003 | 08:23 PM
funina91ss's Avatar
I will sell you my jet air foil for 30 shipped.
Old Jun 25, 2003 | 11:41 PM
Got-LT1's Avatar
Then why do most aftermarket 52mm and 58mm throttlebodies have then installed? There is a samll gain, around 1 to 2 horsepower, but every little bit helps. Just buy used.
Old Jun 25, 2003 | 11:52 PM
turbo_Z's Avatar
all the airfoil does is block off the PCV opening in the TB so your PCV system doesnt work. at least that is the only affect(good or bad) i could see from it.
Old Jun 26, 2003 | 12:12 AM
96cam4ro's Avatar
The trick is you have to buy the right one. The Holley ($55) one really does give power. GMHTP mag got 5.8 RWHP with the Holley airfoil. Personally I tested the same unit and got 4.2 RWHP. Dyno sheets at Powerhouse, OK to back it up.
Pretty good bang for the buck if you asked me.
Old Jun 26, 2003 | 01:12 AM
FacelessZ's Avatar
Airfoil giving 4 rw? Id like to see that dyno...
