Any body have a good write up on how to R&R fuel injectors for 95 Z28?
Re: Any body have a good write up on how to R&R fuel injectors for 95 Z28?
Pretty easy, remove the 4 5/16 (they're probably metric suckers but a ratching 5./16 box wrnech works awesome) on top of the rails, pry the rail up gently with a screwdriver. The fuel injectors should be stuck to the rails with little metal clips, a screwdriver pops these off too. Undo the wiring harness from the injector(s) and pull down a bit to pop them out. Have a handful of new spare injector o-rings, remember to lube them with motor oil before putting them back in too!
You can probably change all 8 in about an hour, I understand most guys don't bother trying to put the little metal clips back on, kind of a PITA.
Jul 4, 2005 05:00 PM
