Any blown head gasket pics?
Old 08-22-2004, 04:49 PM
Wildwill2855's Avatar
Anyone have any blown head gasket pics, i looked but they looked old and used but nothing was blown apart? ill check the intake gaskets but i thought they looked fine?
Wildwill2855 is offline
Old 08-22-2004, 08:58 PM
BAD 97 WS-6's Avatar
Re: Any blown head gasket pics?
I pulled my heads off today. Looking just at the gasket made it hard to tell. I looked at the heads and one cylinder was clean while the rest were black. So I was able to tell where the gasket let loose.
BAD 97 WS-6 is offline
Old 08-23-2004, 12:32 AM
thebrainhart's Avatar
Here are mine.
I apparently blew both gaskets.
One definate coolant leak in cylinder 7 (pic 1) (this one hydro-locked the cylinder), and a definate compression leak in cylinder 2 (into a bolt hole) (pic 2), and one possible coolant leakin cylinder 8 (pic 3).
http://www.ufba.org/forum/index.php?...;id=1819;image
http://www.ufba.org/forum/index.php?...;id=1820;image
http://www.ufba.org/forum/index.php?...;id=1821;image
thebrainhart is offline
Old 08-24-2004, 02:55 PM
Below is the link to my blown gasket. This are the Felpro PT9966. I was told by someone that said they did research that these were just as good as any others. Knowing they were only $18 from Advance Auto, I should have figured they weren't. It only last 1,000 miles. I got white smoke sometimes, but gradually got worse. I knew it wasnt all the way blown because it didnt happen all the time. The material from the gasket started eating away due TO BEING CHEAP!!! I will do my own research next time.
www.marvb3.com/blowngasket.jpg
Old 08-24-2004, 03:07 PM
Hm, i got the 17.99 gaskets from autozone, i wonder if their ****ty to, but their felpro's?
Old 08-24-2004, 03:48 PM
Mindgame's Avatar
Make sure to check the head surface flatness before you bolt everything back together. Especially if you "blew a gasket".
-Mindgame
Mindgame is offline
Old 08-25-2004, 10:42 PM
96speed's Avatar
http://memimage.cardomain.net/member...79_88_full.jpg
Ryan
96speed is offline
Old 08-25-2004, 10:58 PM
97WS6SCharged's Avatar
I got some at the house. I'll put them back into webshots in the morning. I blew the steel compression ring apart and into the water port. It was disturbing.
97WS6SCharged is offline
10-31-2016 11:09 AM
HectorM52
Parts Wanted
01-10-2015 09:01 PM
Jazsun
12-29-2014 12:14 PM
thenewkid
11-27-2014 09:41 AM
Quick Reply: Any blown head gasket pics?
