Which antifreeze?
Old Oct 27, 2011 | 05:32 PM
z86trev's Avatar
Which antifreeze?
WHich antifreeze does my 95 z28 take? It was low when I got it so I added the green stuff. My 95 Impala has the green stuff. I seem to remember the dex cool giving people problems and thought it was used only in 96 and newer. Thanks
Old Oct 27, 2011 | 08:00 PM
raroz28's Avatar
Re: Which antifreeze?
I use the prestone any make stuff. 2 gallons of prestone, 2 gallons of water.
RamAir95TA's Avatar
You can use either one without problems, just don't mix the two types.
Old Oct 27, 2011 | 10:05 PM
95 f-bodies came with either type coolant. There is a label under the hood that says which it came from the factory with (and a look under the radiator cap will confirm). Anyway, you can use the universal coolant they have nowadays.
Pwilson59
Sep 3, 2015 08:47 PM
pimpen1024
Aug 19, 2015 08:36 PM
warmeck
Mar 1, 2015 08:47 PM
TobyZ28
Jun 30, 2003 09:59 AM
Jcb890
May 17, 2003 01:02 PM
