antenna problem
Old Jun 18, 2005 | 07:51 PM
ROWYCO's Avatar
antenna problem
My power antenna goes up and down fine, but the motor acts like it doesn't know when to stop. When the antenna gets all the way up, a really bad sound is made for about 5 seconds, the same think happens when it goes down. Is there a fix for this or do i need to buy a new motor?
Old Jun 18, 2005 | 09:49 PM
Sweetred95ta's Avatar
Re: antenna problem
Don't believe there is a fix for it. I just unplugged mine. Pull it up when you think you will need the radio and put it down if you don't. You could find one in a junkyard.
Benji
Old Jun 18, 2005 | 11:02 PM
3gc's Avatar
3gc
Re: antenna problem
Sounds like the antenna uses the same system the headlights on firebird use to stop. There is probably a stripped gear in the antenna assembly.
siguy
Nov 27, 2014 10:07 AM
97_396_WS6
Aug 4, 2002 10:23 PM
Red97LT1
Aug 4, 2002 08:01 PM
$hawn
Aug 3, 2002 04:59 AM
