Another what will i run!
Old Jun 30, 2004 | 01:42 AM
SilverStreak's Avatar
Hey, just putting on my N02 and i was wanting to see what you guys though i would run.
K&N FIPK, B&B Tri Flo cat back, **** kit, red friction plates, HPP(crap), 3.43, 100 Shot.
edit: it bleeped out FI PK ... for some reason
Old Jun 30, 2004 | 02:44 AM
QCKZ28's Avatar
i would remove the HYPERCRAP "power" programming before you spray...
what is red friction plates?
is it a M6 with 3.42 gears?
with traction you should see low 13's pretty easy
Old Jun 30, 2004 | 11:33 AM
The only thing i use the HPP for is to change my temp and tire highth, should i still take it off?. A4, redfriction plates are just new friction plates in the trans, suposed to grip harder, last longer.
Old Jun 30, 2004 | 12:05 PM
MarkyMark's Avatar
I'm thinking low 13's and if you can hook up than maybe some 12 passes. Have you run the car before without the nitrous? It might help in telling you a before and after with nitrous.
Old Jun 30, 2004 | 12:11 PM
Dave88LX's Avatar
N2O
Old Jun 30, 2004 | 12:14 PM
best with out NX and crappy tracion( i got bad wheel ho) was a 13.8
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
