another what power combo
Should have my project finished this week but won't see a dyno till mid summer so what do u think she will turn?
1995 trans am 6 speed convertible. Afr 1031 195cc lt4 heads, edelbrock lt4 intake, holley 58mm throttle body ,ford matched 42lbs injector,cc 1.6 pro mag rockers and push rods, cc xfi 268 cam ,lt4 timimg chain,centerforce dual friction clutch and flywheel ,3.73 gears, madtuner email tune.stock short block.
Thanks for any thoughts.
I can't give you a number, but I would think that our dyno numbers would be similar. If you have long tubes then I would expect you to have 10 more rwhp. You probably don't need the 42# injectors, but they won't hurt you.
I'll say 360 rwhp (SAE)
May 21, 2015 01:04 PM
