another stumble!
Old Oct 3, 2004 | 08:53 PM
CLEAR's Avatar
another stumble!
yea my 95 6 speed has the "below 2500 rpm, fall on its face, illness"
i did ngk plugs, accel wires, new o2s, map sensor, disabled the egr, deleted the cat converter, and my car still sucks. whats next? timing chain? what is a good brand coil to go with?
Old Oct 3, 2004 | 11:15 PM
chrism400's Avatar
Re: another stumble!
What is this "illness?" Not to be a jerk but my car can't hold bfg's at 2500. Do you think your timing chain has slipped? Is your computer pulling gobs of timing out for some reason?
Old Oct 4, 2004 | 07:30 PM
SkillZ25's Avatar
fuel pump/filter?
Old Oct 4, 2004 | 09:54 PM
CLEAR's Avatar
its the same stumble many board members have. i dont think it is fuel related because my fuel pressure was only about 2 psi under what is should be. once i get to 2500 the tires will spin. btw changed the fuel filter.
just a thought....if timing is off, how about a slp iat module to increase timing 2 degrees??? or is that a bad idea?
93 RedBird
Nov 15, 2015 08:24 AM
tommalcolm
Sep 11, 2015 03:39 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Strick
Aug 31, 2015 11:45 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
