another opti thred???
Old Aug 5, 2010 | 08:45 PM
Jasonz28camaro's Avatar
i have never done an opti before and just pulled mine off, only took an hour. my question is does anyone know of a good way to put it on without it spinning and not lining up right? i have heard of a lot of people doing it wrong so i just dont want to be one of them.
Old Aug 5, 2010 | 08:50 PM
You can make a mark on the outside edge of the drive hub (ex. 12 o'clock or such), so you can watch it from above as you slide it on.
Old Aug 5, 2010 | 09:43 PM
Ok I just never have done it. It was getting dark when I took it off and could not see the dile and all. I'll do that and maybe in the light it will be clear to me thanks.
Old Aug 5, 2010 | 10:29 PM
RamAir95TA's Avatar
FWIW as long as the dowel pin engages in the correct clover on the opti drive it can't be "out of time."
Old Aug 5, 2010 | 11:23 PM
There are 3 positions on the opti and the pin looks like it would fit in any I'm just trying not to put it in the wrong spot
Old Aug 5, 2010 | 11:29 PM
jethrobodean's Avatar
just as long as the opti sits flush with out drawing it on with the bolts your fine....
Old Aug 6, 2010 | 07:32 AM
Not necessarily. Many people have thought they put it on correctly and did not.
Old Aug 6, 2010 | 08:58 AM
i had the msd opti in and i am puting my stock one back in. on the msd it had a built in harness that plugs in on top of the intake manifold, my stock one as you all know does not. does anyone know where to get that extension to go from the intake manifold area to the opti. i called a local dealership and the quoted me $220, they are crazy.
Old Aug 6, 2010 | 02:48 PM
eficonnection, Casper Electronics, lsxtune.com... <$30.
Old Aug 7, 2010 | 06:21 PM
Ool thanks.
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
