another opti bites the dust
Old Jun 18, 2010 | 02:23 PM
cleangene's Avatar
OK, this time I have to change the ignition system or sell, I have searched and found a few threads on putting a carb and hei system in, but nothing answering my question. I want to leave the old opti in place, replace the intake with a gm intake for carb, and put in a low-profile MSD hei distributor, I know there is the problem with firewall, hey I can cut it no problem, what I want to know is can I still run the same computer (tranie control) by leaving the opti in place and let the computer think it is still controlling the fuel, then wire in the MSD unit to the switch, timing I can figure out, seems to me that I should be able to do this. I know it will most likely throw codes but I can tune them out. I have checked on EFI 24x system and that's 2k, I have a carb, all I need is the MSD unit and the intake and few other items to make this work, should be able to get every thing I need for less than $800 and easier to tune.
Any body tried this or know what the computer will do or will not do.
Old Jun 22, 2010 | 01:52 AM
Fatdog2's Avatar
I'm just curious about the few other items to make this work.You are already running fine times,what is your goal here.just wondering?
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
