Another new noise...
Old Jul 13, 2006 | 10:25 PM
tfs95z28's Avatar
Man this car seems to be making all kinds of new noises now that I drive it everyday. Whenever I shut off the car it makes a whistleing noise, its not that loud, but just seems really wierd, cant really pinpoint where it is coming from.
I know this is just so random, just wondering if anybody has ran across this problem before. Im gonna try and pop the hood and listen when someone turns the car off for me. But if anybody has heard of this, im always open for suggestions. Thanks...
Old Jul 13, 2006 | 10:32 PM
Jeremy_30th's Avatar
Re: Another new noise...
mine started doing something like that when I changed my intake elbow (no silencer). It was more of a sssshhhhht //-- noise when I shut it down.. could that be it?
Old Jul 13, 2006 | 11:04 PM
HardcoreRM125's Avatar
Check your antifreeze. Its really common on Dodge 2.5L I4's. We get them alot at the garage I work at. It usually is just a little bit (Like half a gallon low) on antifreeze. For some reason, its enough to make a goofy slosh/whistle noise. Add antifreeze, call it a day.
And, my car, for sure, makes the Shhhhhhtttt. Noise from my CAI when I shut it down.
Old Jul 14, 2006 | 07:22 AM
tfs95z28's Avatar
yeah, i think i know the CAI noise... that is nothing new... ill check out the antifreeze level when it is cold and see.
Hardcore... did you add it directly to the radiator or to the reservoir? Also was it 50/50 mix or straight up antifreeze?
Old Jul 14, 2006 | 09:35 AM
50/50 mix and if the rad is low, we dump it in there, sometimes its pretty close though so we just would pour it in the overflow.
I havent seen this happen on a LT1, but its starting to seem common on the Dodge 2.5's ???
Old Jul 14, 2006 | 11:01 AM
tfs95z28's Avatar
ok, will do... thanks
somebody else on another message board suggested it could be a vacuum leak? Any thoughts?
Old Jul 14, 2006 | 02:40 PM
matLT1's Avatar
I had that same sort of noise coming from around my heater core. Like said above, its probably the antifreeze.
Old Jul 14, 2006 | 02:52 PM
wrd1972's Avatar
In the hot summertime when I turn mine off you can here a whistling sound coming from the gas cap, sounds like a high pitched weezing. If you remove the gas cap a big rush of gas fumes leaving the tank.
Check you gas cap
Old Jul 15, 2006 | 05:42 AM
Checking and adding fluids is new though huh?
MyfateZ28
Parts Wanted
Jun 20, 2015 11:02 PM
97SS0594
Apr 8, 2011 04:35 PM
95silverbullet
Dec 1, 2009 02:14 PM
anasazi
Dec 5, 2003 07:19 AM
