Another lifter Q
Old May 12, 2009 | 12:53 PM
meissen's Avatar
Question Another lifter Q
Should I go with Comp Cam's 850-16 or 875-16?
Old May 12, 2009 | 12:56 PM
wrd1972's Avatar
I would skip the Comps and go GM LS7's.
Old May 12, 2009 | 12:59 PM
meissen's Avatar
Yeah that's what I thought about until my fiance's dealership said the LS7 lifters were over $600 for a set. I'd like to stay as close to $200 if at all possible...
Old May 12, 2009 | 01:13 PM
Stl94LT1's Avatar
You can buy the LS7 lifters for ~$140.
Old May 12, 2009 | 01:14 PM
Hal Fisher's Avatar
Your fiance's dealership is a COMPLETE RIP OFF!!!!! NEVER, EVER, trust a regular car dealership. Everywhere has the regular ls7 lifters for $120 and the race lifter are slightly over $200. part number - 12499225 at either www.gmpartsdirect.com or Summitracing.com
Hal
meissen's Avatar
WOW - My fiance's dealership smokes CRACK! I just looked up the parts # on gmpartsdirect and it's only $114.40 for a set of 16. That's crazy - $500 mark up on a set of lifters?!
Old May 12, 2009 | 06:10 PM
bw_hunter's Avatar
Here, use these:
http://www.sdparts.com/product/88958...esEngines.aspx
BTW the price that GMpartsdirect quotes is dealer cost. Be ready for the fabulous shipping and handling fees to jack that up nicely......
Old May 12, 2009 | 08:25 PM
meissen's Avatar
Do I have to measure pushrod length if I buy those lifters, bw_hunter?
Old May 13, 2009 | 06:20 AM
bw_hunter's Avatar
No, you can reuse the ones you have. I went from stock to these and had exactly the same pattern on the valve stem even though these lifters are slightly taller. I use zero lash + 1/2 turn Vs zero lash + 3/4 turn for the stockers. Of course, these settings will get lots of comments but this is what works for me.....
Old May 13, 2009 | 06:32 AM
wrd1972's Avatar
LS7's are ~$125 all day long.
Old May 13, 2009 | 12:06 PM
bw_hunter's Avatar
Yep, they sure are. Unfortunately LS7 lifters aren't special..they're the same as all LS2 and LS3 lifters and are stock replacements for LS1, LT1 and LT4 lifters. Same parts numbers....
Old May 13, 2009 | 12:55 PM
meissen's Avatar
THANK YOU THANK YOU THANK YOU!!! That's the type of information I wanted to hear.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
FryedClutch
Sep 1, 2015 08:24 AM
