Another hard start thread
Old Jul 17, 2005 | 07:43 AM
BigEvil's Avatar
Angry Frustrated, intermittent hard start
Ok, 94 A4. For a few weeks now, my card has intermittently cranked for an extended period of time before it actually turns over and runs. After driving it for a while, sometimes the car will shake at idle. It also idles at about 500rpm, was 700 before this issue came up.
Just did plugs and wires. Checked the fuel pressure, good. Ignition control module is good.
One possibility is, my intake elbow is torn. Just received my new 1LE elbow yesterday, but haven't installed it yet. Could that cause those symptoms?
If not, what would?
Thanks guys.
Old Jul 18, 2005 | 12:51 PM
BigEvil's Avatar
Re: Another hard start thread
Well, I'm finally home. I'll be installing the 1LE elbow as soon as my car cools a bit. I'll post results.
Old Jul 18, 2005 | 01:28 PM
baddboy1705's Avatar
I'm 99.999999% sure after you do that your problems will go in the trash along with your torn elbow...lol had the same problem, trick flow cereamic coated elbow worked for me! good luck!
Old Jul 18, 2005 | 07:50 PM
BigEvil's Avatar
Well, replaced the elbow and it has started right up 5 times, but that has been itermittent, so we'll see.
The idle smoothed out, and raised up about 50-75 rpms. It seems to accelerate a lot smoother, and be running a bit better.
Hopefully, everything's cool now.
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Alex Barnes
Jan 24, 2015 10:21 PM
squarehead
Jan 15, 2015 07:02 PM
jayblev95
Dec 1, 2014 06:55 AM
