ANOTHER egr block off question
Old Apr 28, 2004 | 12:46 PM
david97gsxr's Avatar
i'm searched and from what i found it seems that i can block off the header primary fitting on #8, and the hole that it runs to on the back of the intake manifold.
and then i can just leave the valve itself on the back of the manifold as long as it is in working condition, it'll work as a block off plate.
i bought a set of block off plates and it came with all three plates, but i can't get the valve off. i got one of the nuts off but the drivers side won't come off. so i' was just going to leave the valve on there.
will that cause any problems?
i've searched, and from what i found it seems i'll be okay. i just wanna make sure.
Old Apr 28, 2004 | 05:29 PM
As long as you remove the vacuum feed so it cannot open, it will essentially be blocked off.
Old Apr 29, 2004 | 10:38 AM
80TA's Avatar
But if mine is defective and leaking will doing that still help.I have a code po400 and car does seem to be sluggish sometimes.
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
jocamino
Dec 29, 2014 10:15 PM
cmdeshon
Dec 27, 2014 10:06 AM
Catmaigne
Dec 25, 2014 12:16 PM
