another CSI pump question
Old Jul 7, 2004 | 11:25 AM
5.7LT1Formula's Avatar
have my new CSI water pump put together. i have the freeze plug put in good even used alil sealeant before pressing it into place. but it still looked like it had the potential to leak. Has anyone plugged the bottom seep hole of the water pump for good measure? to me this looks like how Opti's go bad.
Has anyone put a fuse in on the positive wire of the pump?
I'm thinking about running the positive to the red terminal box and the black ground to the ground terminal on the same fender well. this a good idea or bad?
Old Jul 7, 2004 | 03:12 PM
Super Slow '97's Avatar
I hooked my wires to the terminals on the fender well. And I also ran a fuse on the positive wire. You might want to look in to using a relay also I believe it is recomended. The relay acts like a switch to turn the pump on when the key is turned that way you don't need a separate switch.
Old Jul 7, 2004 | 03:41 PM
izzyz28's Avatar
I hooked my Meziere up through the included fuse to a relay. It's a little more wiring, but it works great. I have it wired to come on with the ignition. I thought the red box on the passenger side was B+ all the time. I never did check it out with a test light. Anyways, as far as the weep hole goes, just plug it up with some JB weld if it's worrying you. I pressed in my freeze plug and then smeared JB weld around the entire thing to make sure there were no leaks. Works great.
Old Jul 7, 2004 | 04:15 PM
MadMaxz28's Avatar
yes you HAVE to plug the little weep hole on the bottom. i used a little bolt and some JB weld.
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Dec 27, 2014 10:06 AM
pologreen97z
Dec 2, 2014 10:42 AM
lbrowne
Nov 13, 2011 04:25 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
