am I screwed?
Old Dec 30, 2006 | 01:33 AM
FLIPPINZ28's Avatar
am I screwed?
I have a 96 z28 I put a 94 lt1 engine in it, Now I have a crank postion sensor code cause i used my 96 computer does the 94 lt1 have a spot for the cps or is there not one on the 94 model? Also if there isnt one on the 94 model what do I do? Will this cause the hard start i am getting?
Old Dec 30, 2006 | 01:38 AM
Compstall's Avatar
You'd be better off installing an OBD1 computer in place of the OBD2 unit to start with.
Old Dec 30, 2006 | 02:02 AM
dhirocz's Avatar
You need to install the timing cover , tone ring and sensor from your old engine to make it work. Not sure on the other sensors but you may want to swap them too. The motor itself isnt any different, you're having a problem with the sensor compatability or lack thereof.
or you could just go with the OBD I pcm. From what I hear, that's the way to go if you plan on lots of mods.
Old Dec 30, 2006 | 03:24 AM
Daniel6718's Avatar
yes you need to fix this...a 94 computer needs a 94 wire harness and pcm..useually get the set off here for 125 bux for both...then install them..and sell yours
Old Dec 30, 2006 | 03:38 AM
FLIPPINZ28's Avatar
Hmm, Can i get it tuned out of my 96 computer? See I have a 96 and here in tennessee they test it by the obd2 port, So I can just put my old cover and sensor on this motor? This is the only plug that isnt plugged up right now, The car runs and drives great just hard to start.
Old Dec 30, 2006 | 03:54 AM
lethal93ta's Avatar
ya just swap the timing cover out, if you used the knock sensors over you will want to swap those out to, there not the same.
Old Dec 30, 2006 | 03:58 AM
FLIPPINZ28's Avatar
The knock sensors arent the same either? Hell my 96 harness pluged right into them and I dont have any codes for them, Where can I get the timing cover and the sensor since the block was junk so I scraped the block with the timing cover on it
Old Dec 30, 2006 | 04:05 AM
lethal93ta's Avatar
nope the 96 knock sensors are diffrent for the OBD2, part number for 93-95 is 10456126 and 96-97 is 10456287. what did you do reuse and old style opti to? and the harness off that. the wire harness is diffrent on a 94 opti than a 96 with a vented one.
Old Dec 30, 2006 | 04:08 AM
FLIPPINZ28's Avatar
Yes I used the old opti that was on the 94 engine, I just used the 94 opti wire for the harness and put my 96 coil on it the 94 engine they are diffrent, So what will it do if I just leave the 94 knock sensors on there since my harness plugged into it?
Old Dec 30, 2006 | 04:17 AM
sbs's Avatar
sbs
Since you need to keep the OBD2 computer for emissions testing, then the solution is to get the CPS code programmed out.
You also need to use the OBD2 KS with the OBD2 computer.
Old Dec 30, 2006 | 04:20 AM
FLIPPINZ28's Avatar
Cool, So I can get it deleted from my 96 computer and not have any effects on the way the engine runs, Starts, or idles I just need to buy some 96 knock sensors then right?Thanks guys for all the help
Old Dec 30, 2006 | 08:34 AM
You only need one knock sensor. (I also answered your email)
Old Dec 30, 2006 | 08:55 AM
Z-RATED94's Avatar
Is this guy the best or what? I don't think we say it enough, but thanks for always helping everyone out.
Old Dec 30, 2006 | 09:00 AM
FLIPPINZ28's Avatar
Thanks shoebox and everyonelse.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
Henson071
Aug 4, 2015 09:32 AM
Z28Freak86
Apr 28, 2015 10:35 PM
squarehead
Nov 21, 2014 08:02 PM
