Alternator for tall Valve Covers
Old Mar 5, 2009 | 04:15 PM
  #16
2cub49's Avatar
Ok
Here's the welded up cover
http://img.photobucket.com/albums/v1...9/103_0930.jpg
http://img.photobucket.com/albums/v1...9/103_0929.jpg
Old Mar 6, 2009 | 09:41 AM
  #17
camarobird92's Avatar
Those look great!
Old Mar 6, 2009 | 01:56 PM
  #18
meissen's Avatar
Originally Posted by James Montigny
The Cantons need a little "percussion maintenance" to get them to clear ProMags, nothing severe.
They do however clear the alternator without issue.
Eh? I've got 1.6 pro mags and had absolutely no problem getting my canton's on?
Old Mar 8, 2009 | 01:32 PM
  #19
2cub49's Avatar
Had I known about the Cantons I would have got them.
My mechanic got the Jegs covers and it was faster to do what we did notching them.
My car has been sitting the last 2 years first getting a new paint job with gold 30th anniversary SS stripes on dark green.
Now there's a fresh 383 that we had some problems with.
2 pushrods pushed through the stock original rockers
but in the meantime the opti took a dump and the ECM got replaced because it wasn't reading codes properly.
So then it was the roller rockers tall covers etc.
Now it's running good ready for the dyno next week.
Thanks for the help.
Old Aug 9, 2009 | 09:55 PM
  #20
user 647483's Avatar
Late follow-up, sorry.
I was running +.100" valves
The >.600" lift, 23x/24x cam + the longer valves and Dart Head
castings forced me to convert to to taller studs (rocker nuts barely had
three threads on the stock height ones). That caused most of my problems.
Also, I had trouble with the rubber gaskets not sealing properly.
I run a modified SBC perimeter cork gasket instead.
However, I have seen several people running 230/236ish cams with stock
studs and ported stock heads who also had to clearance. The photos I
saw indicated that the contact is minimal, but certainly enough to place
resistance on Cyl 2's rocker.
https://www.camaroz28.com/forums/sho...=457848&page=5
See post 67.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
thenewkid
Nov 29, 2014 04:54 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
