Alternator going out??
Old Jul 17, 2004 | 06:42 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
So when i have my car on and turn on the AC i get this HORRIBLE screeching from the alternator area...... It only does it when i turn on the AC. And when it makes the noise the battery voltage drops down and becomes slightly erratic. The alternator is the original which would make it 9 years old. Think its the culprit???
Thanks.
Chris
Old Jul 17, 2004 | 07:14 PM
cmking26's Avatar
Might want to check belt tensioner and AC compressor. You can run alternator in to auto zone and they will check it for free.
Old Jul 17, 2004 | 07:22 PM
n2ceptor's Avatar
Since it only happens when the A/C is on, as stated above check the A/C pulley... Have someone turn the A/C on and off while you can locate the noise.... It might be the tensioner pulley bearing , but that is usually heard at start up.... If you have a voltmeter, the alternator should read around 13.8 to 14.2 volts running at idle.....
Old Jul 17, 2004 | 08:57 PM
Tair's Avatar
check A/C pulley
Old Jul 17, 2004 | 10:30 PM
SLeePer350's Avatar
IF by some chance it is your alternator, I am desperately trying to sell my brand new in box Ac Delco alternator. It has never even been installed on my car...PM me if interested then, good luck
Old Jul 18, 2004 | 07:52 PM
Re: Alternator going out??
I had a friend look at it and he said that it is the ac compressor locking up and causing the belt to slip... So that sucks. Thanks for the quick replies. Time for a new compressor and belt
Chris
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
Thirim
Jul 30, 2015 01:29 PM
