ALTERNATOR Clearance Problem
Old Aug 28, 2007 | 01:18 AM
yy's Avatar
yy
Hello. I just installed a new set of aftermarket valve covers and noticed that the alternator will not fit anymore. By examining the stock ones, I noticed that there was an indentation on the valve cover to make room for the alternator. Since my new valve covers do not have this indentation, is there any way to make the alternator fit or do they sell aftermarket ones that will fit? Thanks.
Old Aug 28, 2007 | 01:23 AM
lt1chevelle's Avatar
are they tall valve covers? if so they will not fit, if you want to run the tall valve covers you need to get the canton fabed ones they have a cut out for the alt.
Old Aug 28, 2007 | 02:28 AM
yy's Avatar
yy
Alternator Clearance
No, the valve covers are standard size. They look identical to the stock ones with the exception of the indentation.
Old Aug 28, 2007 | 03:23 AM
JooneJune's Avatar
(coughuseahammer) Same here. Just used a little force (hammer) and made the chrome set look like the oem set.
Old Aug 28, 2007 | 07:34 AM
PETROC's Avatar
agreed....little bit of hammer...you can't see behind it anyway
Old Aug 28, 2007 | 09:50 AM
adamc's Avatar
the altenator has 2 (think) pieces that hold it on that are not needed.. atleast one i cant remember
the only thing you really need to is the 2 main bolts that hold the altenator on look at the altenator and you'll see what i mean if you havn't done removed them
Old Aug 28, 2007 | 11:29 AM
Vicious95Z28's Avatar
I don't think this is the issue that he's having, no disrespect. You can clearance the back of the alternator. Do a search there is a thread with pics somewhere. I clearanced mine for my Chrome bowtie covers.
Old Aug 29, 2007 | 06:11 AM
yy's Avatar
yy
How much is required to be ground off the back of the alternator? How much is safe? I'm thinking that the metal on the back of the alternator casing is pretty thick???
Old Aug 29, 2007 | 03:10 PM
JAKEJR's Avatar
I had to go with 1/4" taller valve covers on the new 388 I built to clear the Scorpion 1.7RRs. This caused alternator clearance issues too.
I used my grinder and ground off the areas of the alternator causing the interference. I first taped off all the opening on the alternator to prevent the aluminum dust from entering.
Worked fine and the grinding can't be seen with the alternator mounted.
Jake
Old Aug 29, 2007 | 04:06 PM
TobyZ28's Avatar
Some people have ground of the ear of metal on the alternator if the clearance issue is only minor.
Old Aug 29, 2007 | 08:04 PM
jasonisdn's Avatar
go look at the alt for a 96 impala ss. there will be 2 starters listed. look at the smaller of the 2. if you take the face loose and spin it 180 degrees and grind very little off , it will fit. its smaller in size and has slightly less ampage. i had it in my hand today when mine died. i checked the bolt pattern and it matched. i was in just to big of a hurry trying to get ready for a dyno run tomorrow morning, to mess with it. so i got a factory replacement. its a option you can look at.
Old Aug 29, 2007 | 10:35 PM
JAKEJR's Avatar
2 starters? You lost me.
Jake
Old Aug 29, 2007 | 10:39 PM
jasonisdn's Avatar
yep the impala ss shows 2 different alternators listed. they are 2 different sizes and yes i mean physical size. it struk me as weird also. i was looking for another part number because they didn't have the factory piece for my car in stock. call advance and have them look it up tomorrow, for the part numbers. make sure you say 96 impala ss.
Last edited by jasonisdn; Aug 29, 2007 at 10:40 PM. Reason: typed starter instead of alternator
Old Aug 30, 2007 | 12:02 AM
JAKEJR's Avatar
We were discussing alternator clearance, then you mentioned "starters" so I got confused, wondering how we went from alternators to starters.
What did I miss?
Jake
Old Aug 30, 2007 | 11:52 AM
yy's Avatar
yy
I think that it was just a typo? I believe he or she meant alternator. Thanks for the advice and I'll definitely check it out.
