Alternator amp output overkill?
Old Jul 7, 2013 | 07:33 PM
1994BmtZ28's Avatar
Did a scan this morning on my red Z28 & found low ignition voltage. I raised the hood & smelled the alternator getting hot & O'reillys verified it is bad. The GM manual shows 140 amp is stock rating, so why do some fellas install 160 amp (or higher amp) alternators on their LT1s? I have an Optima red top battery, MSD ignition parts, and a stereo amp in the car. Should I consider installing a higher amp unit now or would it be overkill?
Old Jul 7, 2013 | 08:40 PM
RamAir95TA's Avatar
Re: Alternator amp output overkill?
More electrical accessories require more amperage. Typically the people who require higher amperage alternators are the guys with heavy-hitting stereos. For a performance application with a smallish amplifier a stock alt is more than enough.
Old Jul 7, 2013 | 09:57 PM
slick1hunting's Avatar
im running dual amps on my stereo system and have no problem with stock alternator. Very little light fade even with ac on high and headlight and stereo thumpin.
Posted from Camaroz28.com App for Android
Old Jul 7, 2013 | 11:29 PM
1994BmtZ28's Avatar
Maybe it's helpful to have a high amp alternator when ya relocate the battery to the rear of the car. I recall a member postin' they had a 160 amp alternator in their car but not recalling the reason they installed it. There's a racing shop here in town that sells high amp alternators...but they ain't cheap.
Old Jul 8, 2013 | 05:20 AM
slopokrodrigez's Avatar
Have one of the parts stores check out the charging system and see how much current is being pulled with everything on during a hot day.
Old Jul 8, 2013 | 09:25 AM
1994BmtZ28's Avatar
No, they just go out like robots & hookup their meters that are like oversized DTC reader/reset meters they sell. BUT, now that ya mention it, I thought about reading my GM manual to see if there is a test procedure to isolate the overcurrent being drawn in the circuit even though no fuses are blown. They tested my red Z28's battery & alternator @ operating temp. in the car, then the alternator off my white Z28 on a machine in the store, & both tested bad. I say " they verified" my red car's alternator to be bad cuz ya can smell it getting hot.
Old Jul 8, 2013 | 11:37 AM
KW Baraka's Avatar
140 amps = good enough.
160+ amps ain't gonna hurt a thing.
When getting your replacement, get what's available.....as long as it's at LEAST 140 amps .
KW
Old Jul 8, 2013 | 09:11 PM
1994BmtZ28's Avatar
Cool Re: Alternator amp output overkill?
My bad slopokrodrigez...I read your reply like it was a question. I'm gonna go to another Oreillys store where I know the manager...he can show me what you suggested. Problem is there's road construction in front of his store & I didn't wanna sit in any line with this problem goin' on. If it comes down to it I can do like KW Baraka mentioned and go with the 140 amp.
Old Jul 9, 2013 | 07:03 PM
1994BmtZ28's Avatar
Took my white Z28s alternator to a shop specializing in starters, alternators, generators, etc. & their test showed it to be good. Makes me wonder 'bout O'reillys now. This place has been in business since 1944 & it looks like it! Parts in piles everywhere & they know EXACTLY where things are at they're looking for, no computers, and documentation done with pen & paper!!! Anyway, I'm gonna swap it into my red Z28 & go back to test that car's alternator. Onward through the fog...
HibachiZ28
Nov 6, 2015 12:53 AM
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
