Which alternator?
Old Sep 17, 2007 | 03:00 PM
Stormman's Avatar
Which alternator?
For the 94 LT1 there are 2 alternators available and I need to order one. Mine is on the way out. I need to know how I can tell the difference between them without taking it off the car to identify the casting number stamped on it.
Apparently there is a number for design 1 and a number for design 2.
Jason Cromer told me that they both put put 124 amps.
Anyone know?
Old Sep 17, 2007 | 03:03 PM
White96Z28's Avatar
I could be wrong, but I thought the early 94's used the 124 amp and the later ones used a 140 amp alternator...
Old Sep 17, 2007 | 03:26 PM
The 124 amp alternator can be identified by a metal fan and a bolt used to attach the battery cable.
The 140 amp has a plastic fan and a stud to attach the battery cable.
Old Sep 17, 2007 | 08:29 PM
Stormman's Avatar
Thanks guys, Shoebox I am honored that you replied to my thread.
I found out that there is an RPO code for the 140 amp, which I do have n my glovebox (RPO KG9)
What is interesting the 140 amp (Design 2) became the only alternator for 95 & up for LT1's; I wonder if there was something wrong with the previous design that they started offering design 2 same model year?
Anyway, I do thank you guys for your help.
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
Thirim
Jul 30, 2015 01:29 PM
