Allen Bolts for Headers?
Old Dec 28, 2007 | 10:56 PM
My Red 93Z-28's Avatar
Is there a down side to using these? It just seems like these would be easier to use than trying to fit a socket around header primaries
Old Dec 28, 2007 | 11:22 PM
96' Formula WS6's Avatar
The way header bolts are, they probably wouldnt be bad if the bolts are new but as they get some age on them I couldnt see them being any good. It just seems to me that if you put the force on those that I had to put on my stock manifolds a couple weeks ago, they would round right out. I dont know that for a fact and I have no experience with them but thats what I could see happening
Old Dec 29, 2007 | 06:27 AM
cehan's Avatar
Check out Stage 8 header bolts. They are stainless steel hex head bolts but also have an allen hex in the bolt head. The locks that come with the bolts are somewhat of a pain to install, but once they are in and tight, they don't back out.
Old Dec 29, 2007 | 08:34 AM
walt355's Avatar
I used a grabe 8 Socket head cap screw and some SHCS Lock washers I got from sowrk on my first headers. They worked really good. Once you make a couple of allen tools to work the did nicely
Old Dec 29, 2007 | 08:45 AM
96capricemgr's Avatar
Do not fall for the "locking" bolts crap recommended above. Only reason header bolts come loose is the gasket compresses and they lose torque load at which point they can begin to back out. Thing is when the gasket compresses the only way it will continue to seal is if retightened. If you check and retighten header bolts a few times in the first couple weeks after intalling new gaskets the bolts will then stay tight long term without any gimicks needed.
Allen head will work, just get yourself a ball end one you can cut down and then turn it with a ratchet or wrench.
I am using 12point 3/8 and this is good by me, ARP makes some with a 5/16 12 point head which would leave even more tool room.
Old Dec 29, 2007 | 08:51 AM
Ricardo's Avatar
I have used allen bolts on hard to reach places with very good results. I prefer SS socket head bolts and allways use anti seize on them.
Some times I have turned the heads down a bit to a smaller diameter to clear tight radius primaries coming out of the heads. I leave the full head diameter untouched on the contact surface.
Old Dec 29, 2007 | 09:21 AM
dangalla's Avatar
thats what i am using, but i wont tell you it was easy, because no matter what they will always be a pain but the smaller head made it easier to get a wrench on.
Old Dec 29, 2007 | 09:39 AM
Thanks.
Old Dec 29, 2007 | 10:15 AM
speed_demon24's Avatar
I had no problem getting my 5/16 head ARP bolts on. My wrench fit on every one with my jethots.
Old Dec 29, 2007 | 02:10 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I found some stainless steel Breslin header bolts that I used for my Kooks headers. They have a 12 point, 3/8" head. We had to grind the wrench down quite a bit to get access to some of the bolts.
Old Dec 29, 2007 | 02:45 PM
Ratlor's Avatar
I agree with this for the most part. My buddy's car seemed to have those exact same problems with his copper gasket sealing, but my Percy's Seal4Good gaskets seem to have sealed fairly well with using the locking header bolts, even after several thousand miles. It may be the several ply aluminum design that helps it to seal well and not have any blowouts.
Old Dec 29, 2007 | 02:49 PM
The aluminum gaskets don't compress like others, that is why the bolts stayed tight.
Old Dec 29, 2007 | 03:24 PM
1989TransAm's Avatar
Check these out. I have the Breslins on my care with no problems for a few years now. The Breslins are no longer available but these look to be the same fastener.
http://www.route66supply.com/store/page53.html
Old Dec 29, 2007 | 09:37 PM
ricehammer's Avatar
I used socket head cap screws for headers once and they were a pain to deal with + they started rusting shortly after the install.
Old Apr 18, 2009 | 06:05 PM
Highlander's Avatar
where can I get these bolts?
