Allen Bolts for Headers?
The way header bolts are, they probably wouldnt be bad if the bolts are new but as they get some age on them I couldnt see them being any good. It just seems to me that if you put the force on those that I had to put on my stock manifolds a couple weeks ago, they would round right out. I dont know that for a fact and I have no experience with them but thats what I could see happening
Check out Stage 8 header bolts. They are stainless steel hex head bolts but also have an allen hex in the bolt head. The locks that come with the bolts are somewhat of a pain to install, but once they are in and tight, they don't back out.
Do not fall for the "locking" bolts crap recommended above. Only reason header bolts come loose is the gasket compresses and they lose torque load at which point they can begin to back out. Thing is when the gasket compresses the only way it will continue to seal is if retightened. If you check and retighten header bolts a few times in the first couple weeks after intalling new gaskets the bolts will then stay tight long term without any gimicks needed.
Allen head will work, just get yourself a ball end one you can cut down and then turn it with a ratchet or wrench.
I am using 12point 3/8 and this is good by me, ARP makes some with a 5/16 12 point head which would leave even more tool room.
I have used allen bolts on hard to reach places with very good results. I prefer SS socket head bolts and allways use anti seize on them.
Some times I have turned the heads down a bit to a smaller diameter to clear tight radius primaries coming out of the heads. I leave the full head diameter untouched on the contact surface.
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I found some stainless steel Breslin header bolts that I used for my Kooks headers. They have a 12 point, 3/8" head. We had to grind the wrench down quite a bit to get access to some of the bolts.
Check these out. I have the Breslins on my care with no problems for a few years now. The Breslins are no longer available but these look to be the same fastener.
http://www.route66supply.com/store/page53.html
